We are using the BC856ALT1G in our products. Below is the datasheet from ON Semiconductor.
How much does hFE decrease at -40C (low temperature)? How do I calculate the hFE value at low temperature?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWe are using the BC856ALT1G in our products. Below is the datasheet from ON Semiconductor.
This is typical relationship for a BJT , the lowly but still great PN2222A that costs less than a penny.
The temperature coefficient for Beta is called NTB and is given only in SPICE files by OEM
In every case I have seen so far including your device, it is a positive temp coefficient. Although @jonk has more data on this, I have yet to see evidence to the contrary.
For more details https://www.allaboutcircuits.com/textbook/semiconductors/chpt-4/bjt-quirks/
If we have a look at theNexperia datasheet for their similar part number, we can get an idea of what is likely. Of course chances are better it might resemble the 'typical' curves if you specify the Nexperia part. Chances are also better if you operate near the middle of the curve in Ic.
