Does anyone recognise this connector. It is used as power connector on a Targus universal laptop docking station. It is 10mm diameter, 4 pins. Similar to but smaller than the one on the right which is a 4-pin Mini-Din. (The one I bought before I checked the dimensions )
Mystery Connector on the left
Thanks,
  • \$\begingroup\$ You sure about that? The left one looks like mini-DIN to me and the right one some strange larger variant. \$\endgroup\$ – winny May 22 '17 at 11:05
  • \$\begingroup\$ Google finds it easily with '4 pin 10mm din notch' image search. \$\endgroup\$ – user133493 May 22 '17 at 11:07
    \$\begingroup\$ Does this look like it? mouser.com/ds/2/222/KPPX-365228.pdf \$\endgroup\$ – Tut May 22 '17 at 11:42
  • \$\begingroup\$ @winny - Thanks. The one on the right is what I got when I ordered a 4-pin mini-DIN from ebay. \$\endgroup\$ – harry courtice May 22 '17 at 11:57
  • \$\begingroup\$ @Tut, you should make an answer instead of a comment. \$\endgroup\$ – Jeroen3 May 22 '17 at 12:24
It's looks like a typical power plug on high powered laptops. Such as Alienware, Acer or Clevo. It appears to be going around as "DIN-4pin".
Here you can buy the socket.
  • \$\begingroup\$ Thanks. @tut above pointed me to the plug, which is what I'm looking for. \$\endgroup\$ – harry courtice May 22 '17 at 12:02
