Hello I'm very new in electronics/electrical field. I want to know what are these connectors called or where can I find reference source for connector type?enter image description here
  • \$\begingroup\$ In the bottom picture are you wanting the unplugged connector or the ones in the back? The ones in the back are 4 pin Molex Mini Fit Jr (not Molex/ATX as specified below). I believe the one up front is a variation of the Amp Doublelock Series. Still looking into the top as well to get you a correct answer. \$\endgroup\$
    – biggi_
    May 23, 2017 at 20:53
The bottom connector is a Molex/ATX connector. Used on ATX motherboards either for power supply (mostly) and/or data transfer. Used in computers extensively, but isn't limited to them; they can be used in a variety of appliances, such as microwave ovens, [older] TV's, Smart Fridges, and newer electric and gas oven/range combos.
The top connector has no real designation from what I can dig up. It's just a normal power/data connector. However, the 40-pin variants were used in old Hard Drives before 2006ish for serial data communication.
For more info about Molex/ATX connectors, click here.
