I am trying to send init command to DOGM128-6 LCD Module from STM32F103RC MCU via SPI (SPI1):
static const char UE_CMD_INIT_DOGM128_6[] =
    0x40, /*Display start line 0                    */
    0xA1, /*ADC reverse, 6 oclock viewing direction */
    0xC0, /*Normal COM0...COM63                     */
    0xA6, /*Display normal, not mirrored            */
    0xA2, /*Set Bias 1/9 (Duty 1/65)                */
    0x2F, /*Booster, Regulator and Follower On      */
    0xF8, /*Set internal Booster to 4x              */
    0x00, /*                                        */
    0x27, /*Contrast set                            */
    0x81, /*                                        */
    0x16, /* <- use value from LCD-MODULE .doc guide*/
    /*    for better contrast (not 0x10)      */
    0xAC, /*No indicator                            */
    0x00, /*                                        */
    0xAF, /*Display on                              */
    0xB0, /*Page 0 einstellen                       */
    0x10, /*High-Nibble of column address           */
    0x00  /*Low-Nibble of column address            */
The SPI1 perihperal is initialized with following chunk of code:
GPIO_InitTypeDef ueDOGM128_PinMappingsHandle;
SPI_InitTypeDef ueDOGM128_CommHandle;
void ueInitSystem(void)
    // **** INIT CODE ****
    SystemInit();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,
        ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,
        ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,
        ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,
        ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD,
        ENABLE);
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,
        ENABLE);
    ueDOGM128_PinMappingsHandle.GPIO_Pin=UE_LCD_SPI_SCK_Pin|UE_LCD_SPI_SI_Pin;
    ueDOGM128_PinMappingsHandle.GPIO_Mode=GPIO_Mode_AF_PP;
    ueDOGM128_PinMappingsHandle.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(UE_LCD_SPI_GPIO_Port,
        &ueDOGM128_PinMappingsHandle);
        ueDOGM128_PinMappingsHandle.GPIO_Pin=UE_LCD_RST_Pin;
    ueDOGM128_PinMappingsHandle.GPIO_Mode=GPIO_Mode_Out_PP;
    GPIO_Init(UE_LCD_RST_GPIO_Port,
        ueDOGM128_PinMappingsHandle.GPIO_Pin=UE_LCD_A0_Pin;
    GPIO_Init(UE_LCD_A0_GPIO_Port,
        ueDOGM128_PinMappingsHandle.GPIO_Pin=UE_LCD_CS_Pin;
    ueDOGM128_PinMappingsHandle.GPIO_Speed=GPIO_Speed_2MHz;
    GPIO_Init(UE_LCD_CS_GPIO_Port,
    GPIO_PinRemapConfig(GPIO_Remap_SPI1,
        ENABLE);
    GPIO_WriteBit(UE_LCD_RST_GPIO_Port,
        UE_LCD_RST_Pin,
        Bit_SET);    // wake up LCD from RESET state
    ueDOGM128_CommHandle.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_8;
    ueDOGM128_CommHandle.SPI_CPHA=SPI_CPHA_1Edge;
    ueDOGM128_CommHandle.SPI_CPOL=SPI_CPOL_Low;
    ueDOGM128_CommHandle.SPI_CRCPolynomial=0x07;
    ueDOGM128_CommHandle.SPI_DataSize=SPI_DataSize_8b;
    ueDOGM128_CommHandle.SPI_Direction=SPI_Direction_2Lines_FullDuplex;
    ueDOGM128_CommHandle.SPI_FirstBit=SPI_FirstBit_MSB;
    ueDOGM128_CommHandle.SPI_Mode=SPI_Mode_Master;
    ueDOGM128_CommHandle.SPI_NSS=SPI_NSS_Hard;
    SPI_Init(UE_DOGM128_COMM_PORT,
        &ueDOGM128_CommHandle);
    SPI_Cmd(UE_DOGM128_COMM_PORT,
        ENABLE);
    ueDOGM1286Init();
and then I am trying to initalize LCD with ueDOGM1286Init() function:
void ueDOGM1286Init(void)
    GPIO_WriteBit(UE_LCD_CS_GPIO_Port,
        UE_LCD_CS_Pin,
        Bit_RESET); // CS to LOW (Chip Select for DOGM128-6 LCD)
    GPIO_WriteBit(UE_LCD_A0_GPIO_Port,
        UE_LCD_A0_Pin,
        Bit_RESET); // AO to LOW (set COMMNANDS mode for DOGM128-6)
    for(uint16_t ueDataIndex=0; ueDataIndex<sizeof(UE_CMD_INIT_DOGM128_6); ueDataIndex++)
        SPI_I2S_SendData(UE_DOGM128_COMM_PORT,
            UE_CMD_INIT_DOGM128_6[ueDataIndex]);
        while(!(SPI1->SR&SPI_I2S_FLAG_TXE));
//        while(!(SPI1->SR&SPI_I2S_FLAG_RXNE)); // not needed since MISO pin is not connected
        while(SPI1->SR&SPI_I2S_FLAG_BSY);
    }   // for
        UE_LCD_CS_Pin,
        Bit_SET); // CS to HIGH (deselects DOGM128-6 LCD)
}    // ueDOGM1286Init
and whatever I do, in the Keil debugger Window SPI1's Data Register (DR) is always set to value 0x00:DR Register 0x00 What did I miss or what am I doing wrong?
This is normal.
SPI->DR is a dual-purpose register. Writing to it makes the SPI peripheral output data to a device; reading from it returns data that the SPI peripheral received from a device. There is no way to read back the data that you wrote to the register, even in a debugger.
What I do see which might be a problem is that you aren't initializing the A0 and SS GPIO pins as outputs.
  • \$\begingroup\$ Yes A0 and SI were not initialized, however, the problem persists, I've checked the output of SPI phisically on MCU's pins with scope, no activity. And I've upgraded the code with pins init. \$\endgroup\$ – KernelPanic May 24 '17 at 6:09
