I am new to pic uart communicatioon with PC using RS232. I have tried the below code and used Hyperterminal to view the output. But the output gets scrambled here and there each time when I reset pic. I have tried changing stopbits from 1 to 0 in the hyperterminal but the output remains the same. The settings kept on hyperterminal is
  1. Baudrate 9600
  2. Parity none
  3. Stopbits 1 & 2(for both the output remains the same.)
  4. No. Of bits 8
Am using PIC16F877a and have coded using MPLAB XC8 compiler The outputs are there in the attachment
Could you please tell where i did the mistake.
void main()
TRISC = 0x80;
TXSTA=0x24;
RCSTA=0x90;
SPBRG=0x81;
unsigned int i=0;
char name[]="Sample Output";
while(name[i]!='\0')
  TXREG=name[i];
  while(!TXIF);
  __delay_ms(1000);
  i++;
while(1);
    \$\begingroup\$ How did you come up with 0x81 for SPBRG? How is your micro clocked? \$\endgroup\$ May 24 '17 at 12:10
  • \$\begingroup\$ How is the PIC wired to the PC? What cable and connector is used? \$\endgroup\$ May 24 '17 at 13:25
  • \$\begingroup\$ @Vladimir Cravero ..Am using 20Mhz on board crystal oscillator for clocking. And I choosed 0x81 by the formula SPBRG = (FOSC-(baud rate*16))/(9600*16) \$\endgroup\$
    – Sreez..
    May 25 '17 at 2:32
  • \$\begingroup\$ @Entrepreneur I have used a DB9 connector which is then connected to a RS232-to-USB converter cable \$\endgroup\$
    – Sreez..
    May 25 '17 at 2:37
  • \$\begingroup\$ Definitely don't want to guess stop bits, it could throw you out of sink \$\endgroup\$
    – sstobbe
    May 25 '17 at 3:34
I think you need to poll the Transmit Shift Register Status TRMT rather than TXIF. When TRMT==1 the register is empty and it is ready to transmit a byte.
But upon a second look I notice that the wrong characters are always off by the same bit in the ASCII code. When a character is wrong the first (low order) bit in the ASCII character is supposed to be 1, but it is replaced with a 0. 'S' turns into 'R', 'O' into 'N', 'u' into 't'. That seems like a signal integrity issue over the data cable.
While I do think that you will need to poll the TRMT bit, I don't think that your current problem is software. Look for anything that may affect the quality of the cable connection.
  • \$\begingroup\$ But while doing the loop back test, the results are positive. If anything was wrong with the cable then i should have known at that time right? By the way I did replace TXIF with TRMT. :) \$\endgroup\$
    – Sreez..
    May 25 '17 at 4:55
  • \$\begingroup\$ thanks to you. Finally figured it out that the problem was with the cable. And the error was also seen during the loop back test when i gave repeated 'A' as input. :) \$\endgroup\$
    – Sreez..
    May 25 '17 at 6:18
