I am receiving coordinates from my GPS module like mentioned on below.
uint8_t *latPtr = tmpPtr + 1;
when I am writing latPtr value in UART I can view lat value in terminal.
uartwrite(latPtr); // output is 1257.4370N
Find my uartwrite function on below
void uartwrite( char *data)
  while(*data)
    EUSART_Write(*data);
    *data++;
Now I want to convert the lat value in to degree minutes seconds format. So that I have written below mentioned code on my main file
float res1=*lonPtr;
float flo=res1/100;
int ilong=flo;
float lati=flo-ilong;
float res1=lati*60;
int minutes=res1;
uartwrite(minutes);
float isec=res1-minutes;
int lasec=isec*60;
uartwrite(lasec);
uartwrite("\n\r");
how to send DMS to UART?
  • \$\begingroup\$ This output, what format is this? \$\endgroup\$ – sweber May 27 '17 at 5:57
    \$\begingroup\$ Apparently you have a pointer to a string. You must convert that string to a (floating point) numerical type ("atof"), do your calculations, and convert the results back to a string for output. "float res1=*lonPtr;" won't do. \$\endgroup\$ – JimmyB May 27 '17 at 17:01
  • \$\begingroup\$ I have used atof ( float res1=atof(data);) and its working \$\endgroup\$ – user1811790 May 29 '17 at 12:28
