I'm confused about the role of the
Let's assume that I want to use it along with a and I want to flash it with
The adapter should be used with both CP2102 and the relay or just with the relay?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityESP8266 adapter can be programmed using CP2102.
You can program your ESP8266 GPIO pin to trigger the relay.
Once the circuit will be fully functional, you can remove CP2102 module from the circuit. It is used only for programming.
