First of all I am new to this whole circuit building thing so please don't be too harsh on me.
I recently tried to build my first adder with NAND gates. So I went to a shop and bought some CD74HCT03E devices. To get started I just tried out the NAND gate but it didn't work.
I had a really really basic setup: a NAND gate, the power supply, and a LED. I already verified this circuit with my physics teacher and he sad that everything is fine. I also checked every pin with my voltmeter. Every input (A/B grounded) were at 0V and the output (Y) flicker but were also at 0V.
Here is an image of my circuit: IMAGE
  • \$\begingroup\$ We can help you better if you include the schematic of what you're buidling. Scan a drawing or better: use the schematic drawing tool (Edit your question, press the schematic icon). \$\endgroup\$ – Bimpelrekkie May 31 '17 at 14:44
74HCT03 is open drain output. That means it can only pull the output low.
Try it this way..
  • \$\begingroup\$ Thank you really much, that schematic really helped me :) \$\endgroup\$ – Nimmi May 31 '17 at 15:09
The banner line title of the CD74HCT03E is
High-Speed CMOS Logic
Quad 2-Input NAND Gate with Open Drain
You got really unlucky on your first purchase, the NAND gate you purchased only drives low, it never drives high. It is an open-drain output.
You will need to add a pull-up resistor on 1Y to VCC.
You can also connect the LED directly to 1Y and move your ballast resistor as the pull-up to Vcc.
  • \$\begingroup\$ Thank you really much for you answer, it is working now :) \$\endgroup\$ – Nimmi May 31 '17 at 15:09
  • \$\begingroup\$ @Nimmi The part which you probably meant to buy is the 74(HCT)00, which has a "normal" (push-pull) output. \$\endgroup\$ – duskwuff May 31 '17 at 22:37
Try this circuit. It's how it should be connected.
Two 1's light LED.
Open Drain (collector) have their applications, but it may be best to stay away from them when experimenting. Each output will require a "pull-up" to work.
One application is paralleling gates to a "wired OR" (or "wired AND") in this case. Otherwise a third gate is required.
In the following circuit, activate either NAND to turn on LED.
  • \$\begingroup\$ YUp this will work too.. though inverted \$\endgroup\$ – Trevor_G May 31 '17 at 15:13
  • \$\begingroup\$ @Trevor But that is how it is meant to be used. 8) \$\endgroup\$ – StainlessSteelRat May 31 '17 at 15:16
  • \$\begingroup\$ I'd say so..yes ;) \$\endgroup\$ – Trevor_G May 31 '17 at 15:22
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
