I just built up a circuit with a LM311P comparator with open collector and emitter (I don't think that's relevant). The negative input is a voltage I create with a voltage divider and the positive input is the signal I want compared.
However it seems like the comparator is heavily loading the voltage divider because the voltage at the negative input looks like this (yellow trace), blue trace is the output signal.
It's fluctuating by almost 2V. And this is after I already made the voltage divider smaller. The fluctuation was even worse with a combined resistance of about 20kOhms. I know I can stabilize it with a big capacitor but I first want to understand where this is coming from. Here is a screenshot from the datasheet of LM311P (http://www.produktinfo.conrad.com/datenblaetter/175000-199999/175994-da-01-en-IC_LM_311P_DIP8_TID.pdf):
The current through the voltage divider is 2.1 mA which is 7000 times as big as the worst case bias current of 300nA.
Am I missing something here? Any help understanding why this is happening would be very appreciated.
  • \$\begingroup\$ Measure your power supply - you'll probably see it is also changing. How much current do you think flows from the comparator through the transistor's BE junction with no resistance to limit it ... ? \$\endgroup\$
    – brhans
    Jun 1, 2017 at 16:11
    \$\begingroup\$ @brhans I think that's just the way he drew it here..that transistor is internal. BEsides... if that were the case the droop would be on the output when low. \$\endgroup\$
    – Trevor_G
    Jun 1, 2017 at 16:17
  • \$\begingroup\$ Thanks for your suggestion, but I did measure the power supply and it doesn't change (noticeably). The transistor is symbolizing the open collector output that is integrated into the comparator. \$\endgroup\$
    – Felix S
    Jun 1, 2017 at 16:23
  • \$\begingroup\$ DId you leave the balance /strobe pins open? \$\endgroup\$
    – Trevor_G
    Jun 1, 2017 at 16:26
  • \$\begingroup\$ yes I did. I just found the problem. Sorry for wasting everyone's time! \$\endgroup\$
    – Felix S
    Jun 1, 2017 at 16:27
The problem was that the input signal went below zero. It can go a little negative without problems but at around a diode forward drop it starts loading down the inputs. Sorry for wasting everyone's time. Should I delete this question?
  • 5
    \$\begingroup\$ no leave it here...someone else might have the same issue. \$\endgroup\$
    – Trevor_G
    Jun 1, 2017 at 16:33
  • \$\begingroup\$ It's a good question. Don't delete. \$\endgroup\$ Jun 1, 2017 at 17:19
    \$\begingroup\$ Go ahead and mark as accepted. \$\endgroup\$
    – JRE
    Jun 1, 2017 at 17:26
