9
For a 2-layer PCB, should there be a ground plane under a 16 MHz oscillator? From this PDF document, http://www.nxp.com/assets/documents/data/en/application-notes/AN2500.pdf, it shows the following figure, enter image description here which suggests not to have any ground plane under the oscillator components.
whereas a response from here (When to use ground plane cutouts?) says:
In fact, it is highly recommended to run your high-speed signals directly overtop of an unbroken ground plane;
So my questions are:
  1. Would the lines for a 16 MHz oscillator be considered "high-speed"?
  2. Would it be correct to not have any ground or power planes under 16 MHz oscillator lines + related components?
  • \$\begingroup\$ The board will probably work fine either way. But I would keep the ground plane solid. The data sheet is worried about capacitance throwing off the performance of the crystal. Maybe the frequency. Or maybe just the reliability. But you can fine tune it by changing the capacitor values. I would be more worried about radiated emissions, so I would use a solid ground plane. \$\endgroup\$
    – user57037
    Jun 2, 2017 at 7:15
  • \$\begingroup\$ A 16MHz oscillator creating a 16MHz sine (medium speed more like) or conditioning a fast rise squarewave from it (f... high speed)? \$\endgroup\$ Jun 2, 2017 at 12:20
  • \$\begingroup\$ From here, forum.arduino.cc/index.php?topic=60662.0, I would assume its creating a 16 MHz sine wave, as I'm using a crystal oscillator with similar specs. (30 ppm frequency tolerance). If its considered "medium speed", then would the ground plane considerations not matter as much? \$\endgroup\$
    – plu
    Jun 2, 2017 at 22:50
9
Choosing ground cutouts on the basis of the signal's speed is only part of the story. The oscillator, and the 'high speed signals' your link talks about, are different situations.
The oscillator is recommended to use a specific circuit layout. This is a very small circuit. Follow the data sheet. An adjacent ground plane would introduce much C to ground. It's likely that the oscillator requires certain ratios of capacitance, and maximum capacitance to function properly, hence their recommendation. At the frequencies involved, for the line lengths shown, it all works, don't sweat it, just follow the data sheet. The 'to minimise parasitics' statement confirms that it's the excess capacitance that they are concerned about. Even if it does not stop oscillation, excess C will increase power consumption, which could be an issue on lower power designs.
'High speed signals' crossing a ground plane from one IC to another should have a well-defined return current path close by. The simplest way to do this is with an unbroken ground plane underneath. There are other methods, if you know what you're doing, but the unbroken ground plane is easy to do and always works. If you introduce breaks or cutouts in the ground plane, then this disrupts the return current flow, which can cause all sorts of problems which can be quite difficult to diagnose.
It is important that when you've cleared a patch of ground plane under your oscillator that you don't then route a different high speed signal across that area, both for problems with that signal's integrity, and potential problems of interference to/from your oscillator.
AFAIK general requirements for any passive XTAL circuit are same: XTAL branch must be isolated from the rest as much as possible since it is critical to avoid parasitics. Usually these are:
  • Components must be placed close as possible to IC, with short traces
  • No high speed traces passing nearby or under
  • Avoid crosstalk / coupling between traces
  • GND part must be isolated from "general" GND. If plane is used, it must be separated by gap (even from "general" GND plane)
  • Sometimes guard ring around is recommended - GND path with vias (check STM AN2867 for example)
Regarding various techniques, I think it is better to figure out why (requirements) and then decide what fits and what is not.
Given $$Tjitter = Vnoise / SlewRate$$ and $$SlewRate = 2*pi*16MHz*1volt = 100 volts/uS$$ you need to identify the tolerable Tjitter and be realistic about the dB/dT (change in magnetic interference near the XTAL/Cpi1/Cpi2/ MCUGND/MCUVDD/XTALin/XTALout).
Suppose your PCB has SwitchingReg with 100MHz discontinuous ringing of amplitude 0.1 amps, 1cm from the XTAL/Cpi. 100MHz may be seriously attenuated by SkinDepth, depending on direction of arrival at 1cm by 1cm XTAL/Xpi area.
Using $$Vinduce = MU0 * MUr * Area / (2 *pi * distance) * dI/dT$$ the induced $$Vnoise = 2e-7 * 1cm * 1cm / 1cm * (0.1 * 628e+6)$$
Vnoise is 2e-7 * 0.01 * 63e+6 = 126 e-7-2+6 = 126e-3 = 0.126 volts.
The resultant XTAL Jitter, out of the onchip sin-to-square circuit is as before $$Tj = Vnoise/SlewRate$$ = 0.126 volts/10^+8volt/sec = 10 nanoseconds * 0.126 = 1.26 nanoseconds.
Can your system tolerate 1.26 nanoseconds of jitter, caused by the nearby SwitchReg upsetting the XTAL voltages?
At 16MHz, period 66ns, the 1.3 ns jitter is 2%.
  • 6
    \$\begingroup\$ given the noob nature of his question, do you really think you're advancing the state of his understanding talking about jitter, with a mass of untidy equations that would be better rendered in mathjax? I notice you have 2 downvotes, and neither of them is mine (yet). \$\endgroup\$
    – Neil_UK
    Jun 2, 2017 at 5:35
  • \$\begingroup\$ I intend on avoiding any switching parts in the power supply (i.e.: battery / lab power + linear voltage regulator). Would jitter be a problem in this case? \$\endgroup\$
    – plu
    Jun 2, 2017 at 7:52
  • \$\begingroup\$ How close is the MCU databus or clockline or SPI enable? An MCU line, with 2.5v/2.5nS into 50pF produces 0.05 amps current, which is 50% of the 100mA example I used above. The phase noise is Constant + (Tj)/ClockPeriod. At best , with 1.2nS/66nS, your phase noise is 1/50 = -34 dB, not usable for Audio Playback nor for sampling ADC inputs, but OK for fully settled sensor measurements. [remember the "Constant"] \$\endgroup\$ Jun 2, 2017 at 16:58
  • \$\begingroup\$ Looking at my PCB design, the nearest CS enable pin that will be used is 4.64 mm (~182 mils) away, and the distance from the SPI clock is farther than that. Would these factors be a problem if my ADC sampling frequency is very low, like around 10 kHz or less? \$\endgroup\$
    – plu
    Jun 2, 2017 at 21:21
  • \$\begingroup\$ Running 5volt CS and SPIclk near the Cpi1/2 nodes will inject voltages (magnetic fields) and charges (electric fields). Having GND planes underneath will reduce the injected energy; moving aggressor and victim traces 2X further apart will reduce the energy 1/D^3 for Efield injection. Does your ADC handle music? voice? sensor info? \$\endgroup\$ Jun 3, 2017 at 6:38
