I got a AC voltage sensor to measure AC voltage. And I want to know its input impedance. But the sensor's data sheet only tells how to use it, doesn't tell the internal details. It's used as below:
The \$R_{i}\$ is calculated as:
$$R_{i} = U_{i} \times 1K \Omega/V $$
Rated output is 1mA, max load voltage 1.2V, rated input signal frequency 25Hz~5kHz.
That's the main specifications.
That is, if Ui = 1V, Ri = 1KOhms, and a 1KOhm resistor connected between Pin 3 and Pin 4, I can get about 1V output.
I think the internal is basically a current/voltage transformer. But how can we deduce its input impedance with some specific load resistor?
  • \$\begingroup\$ How about a link to the data sheet? \$\endgroup\$ – Andy aka Jun 2 '17 at 10:39
  • \$\begingroup\$ @Andyaka, there isn't a data sheet in English, only a Chinese version. And it's in a 'catalog', several tens of MBytes. \$\endgroup\$ – diverger Jun 3 '17 at 6:08
Attach an appropriate load to the device and an appropriate input voltage to the device. Measure the AC voltage directly across the input terminals of the device. Call this E 1 . Measure the voltage across one of the input resistors, R. Call this E 2.
Now calculate the current through the circuit as:
I1 =E 2/R
Now calculate the input impedance as:
|Z|=E 1 /I1
  • \$\begingroup\$ The current may be as low as 1mA, so I need a DMM with AC resolution at least 1mA. \$\endgroup\$ – diverger Jun 2 '17 at 6:29
  • \$\begingroup\$ Read it again. No current meter needed \$\endgroup\$ – Glenn W9IQ Jun 2 '17 at 14:37
  • \$\begingroup\$ Ok. And do you think it's a 1:1 transformer internal? \$\endgroup\$ – diverger Jun 3 '17 at 6:05
  • \$\begingroup\$ Since it appears to be a passive device, it is likely that it contains a transformer of some type. Perhaps a small current transformer. These transform an input current to an ouput voltage. There are lots of web references you can use to learn more. \$\endgroup\$ – Glenn W9IQ Jun 3 '17 at 10:02
