I am trying to connect ATMEGA328p as master to X25020 EEPROM as slave.
here is my code
void spi_master_init()
DDRB = ( (1<<PB2) | (1<<PB3) | (1<<PB5) ); // /SS as output, MOSI and SCK as output
SPCR = ( (1<<SPE) | (1<<SPR1) | (1<<MSTR)); //SPI Enable, fosc/64, Master mode
void spi_slave_init()
DDRB = 0<<PB4; //MOSI as input
SPCR = 1<<SPE ;
void SPI_Tx(char data)
SPDR=data;
while( !(SPSR & (1<<SPIF)) ); //wait until SPIF flag is set, to indicate transmission is complete
char SPI_Rx()
char Rx_char;
Rx_char= SPDR;
return Rx_char;
void write_to_slave()
PORTB|=1<<PB2; //take /CS on slave LOW
SPI_Tx(0x06); //WREN write enable command
PORTB&=0<<PB2; //take /CS on slave HIGH
SPI_Tx(0x02); //WRITE instruction
SPI_Tx(0x20); //Address to write data to
SPI_Tx(0x01); //Data to be written
char read_from_slave()
char recvd_char;
SPI_Tx(0x03); //READ instruction
SPI_Tx(0x20); //Address to be read from
recvd_char = SPI_Rx();
return recvd_char;
int main (void)
DDRC=0xff; //PORTC as output
char recvdchar=0;
spi_master_init();
spi_slave_init();
write_to_slave();
recvdchar=read_from_slave();
if(recvdchar==0x01)
PORTC=1<<PC0;
The idea is to write 0x01 to address 0x20 on the slave chip, and read it back, if successfully read light up an LED on PC0.
Somehow i cant see why it does not work, I checked connections of slave chip, seem to be fine.
followed datasheet instructions to talk to the slave chip.
