I have a system that is using the built-in firmware loading facility of the LPC1343. When the flash drive is mounted, the disk is always labeled "CRP_DISABLED". Is there a way to change the label of the drive to something else?
This label is in ROM, and cannot be modified as far as I know. Only NXP can change this in their production process - but they need good reason ($$$$$) to do this.
The only thing you could do is to write your own boorloader. But given the small RAM (8k) and Flash (32k) of the device, this will be problematic, too - unless you have much space free in Flash.
| improve this answer | |
  • \$\begingroup\$ I figured this was probably the case. Now it is confirmed! \$\endgroup\$ – BrianV Apr 30 '12 at 19:19
In the boot mode, the ROM will determine what the volume label will be when entering USB-ISP. According to the manual, the volume label will reflect the state of the code-protection bits (CRP). Seeing "CRP_DISABLED" means that the chip has not been code-protected, and you can read and/or write the flash memory. Seeing any other volume label means that there is some level of code protection. (Read the user-manual for information on these).
Also, note that due to a bug in some versions of the USB-ISP, you may have to wait for a second "connect" retry from the device, which can take around 15 seconds. (This is documented in the user-manual).
Another thing-- if you use anything other than a Windows machine, you are going to have problems. Windows writes sectors to disk drives on a "first available cluster" basis-- so, your firmware file will be written onto the device in the expected sequential order. On non-Windows OS's, files are NOT written to "first available cluster" basis-- the files are written in (seemingly) random order. This is the case with any of the *BSD's, Linux, and Apple OS/X (which is based on OpenBSD). I can't remember why they do this-- maybe security or performance reasons-- but that doesn't matter, because if you erase the "firmware.bin" file, you will need a Windows machine to write it back. (Or, if you have the "mtools" package available for installation with your O/S, "mcopy" can write this file without any issues). Another way to deal with non-Windows OS's in this situation-- If you don't first DELETE the file (like the user-manual suggests), your non-windows OS can open the file for writing, then copy the new firmware to the open file-- this will use the "clusters" (flash sections) in the same order as they originally appeared-- in sequential order.
But anyway, sorry-- no, you can't change the volume-label on the USB-ISP-MSD.
  • \$\begingroup\$ Great to know. We had a user have an issue with the bootloader on OS X. I thought it was a software issue as he had been running an older version of the firmware and upgraded to a new version with different configuration settings. This is the reason, and sounds like we'll need to create a custom tool for loading the FW on OS X. \$\endgroup\$ – BrianV Sep 11 '12 at 15:11
The LPC1343 has USB drivers in ROM but you can change the descriptors. It is documented in the User Manual: http://www.nxp.com/download/pip/LPC1343FHN33/user_manual
  • \$\begingroup\$ To clarify, this is for the firmware loading facility, not the onboard USB mass storage driver. \$\endgroup\$ – BrianV Apr 30 '12 at 19:18
  • \$\begingroup\$ Well, that was what you asked about. \$\endgroup\$ – morten Apr 30 '12 at 20:49
