Does the Schottky diode current rating affect the performance of a DC to DV buck converter when loaded? I'm using a 1N5822 Schottky diode instead of a 1N5825 on a National Semiconductor LM2596S-ADJ based buck converter design.
My output voltage drops when I load the circuit with a 100 Ω or 50 Ω resistor. The voltage drops by nearly 0.25 V and 0.40 V respectively.
My design is not yet on a PCB, I'm testing it on a breadboard.
