So i am trying to establish a connection between ATMEGA328p as Master and 24LC256 EEPROM Chip using I2C protocol.
  • Clock is set to 100KHz
  • SDA and SCK lines are pulled up to Vcc using 4.7K Ohm resistors,
  • Start condition works fine, i get a ACK in return too,
  • ACK received when the right address is sent,
  • Fails when MSB of the address in the chip is sent!
Code:
#define FOSC         16000000UL
#define START        0x08
#define MT_SLA_ACK   0x18
#define MT_SLA_NACK  0x18
#define DEV_ADDR     0x50
typedef enum result_t{FAIL, SUCCESS}result;
void Debug_LED_ON()
   PORTD|=1<<PD4; //Turn on LED on PIN4 of PORTD
void set_clock(int freq_in_khz)
   TWCR = 1<<TWEN;     //Enable TWI module
   TWSR |=(1<<TWPS0); //Prescaler set to 4
   TWBR  = FOSC/freq_in_khz;
   TWBR -= 16;
   TWBR /= 8;  //2*Prescaler_value
void send_start()
   TWCR= ( (1<<TWINT) | (1<<TWEN) | (1<<TWSTA) ); //send START
   while( !(TWCR & (1<<TWINT)) ) ;                //wait for TWINT flag SET
void send_stop()
   TWCR= ( (1<<TWINT) | (1<<TWEN) | (1<<TWSTO) ); //send STOP
   //while( !(TWCR & (1<<TWINT)) ) ;                //wait for TWINT flag SET
result check_start_status()
   if ((TWSR & 0xF8) == START )
     return SUCCESS;
   else
     return FAIL;
void send_address(char addr_w)
   TWDR=addr_w; //7bit  address + W bit (write bit)
   TWCR = (1<<TWINT) | (1<<TWEN); //Clear TWINT bit to start transmission of address
   while (!(TWCR &(1<<TWINT)));  //wait for TWINT flag SET
result check_MT_slave_ack()
   if ((TWSR & 0xF8) == MT_SLA_ACK )
     return SUCCESS;
   else
     return FAIL;
result check_MT_slave_nack()
   if ((TWSR & 0xF8) == MT_SLA_NACK )
     return SUCCESS;
   else
     return FAIL;
void  transmit_data(char data)
   TWDR=data;
   TWCR = (1<<TWINT) | (1<<TWEN); //Clear TWINT bit to start transmission of Data on the bus
int main (void)
   DDRC=0xff;
   PORTC=0x30;   //Enable internal pullups on PORTC PINS  SDA(PC4) , SCL(PC5)
   DDRD=0xFF;   //Port D as output
   set_clock(100); //setting clock 100KHz
   send_start();
   if(check_start_status()==FAIL)
     Debug_LED_ON();
   send_address(DEV_ADDR << 1);
   if(check_MT_slave_ack()==FAIL)
    Debug_LED_ON();
   transmit_data(0x00);
   if(check_MT_slave_ack()==FAIL) //fails here!
    Debug_LED_ON();
   return 0;
Guess somethings wrong with the code, or the way i send the address! A2,A1,A0 bits of 24LC256 are set to ground, therefore the device address is 0x50 << 1.
Update:
The device address is correctly sent now, now when i send the MSB of Address on the chip where i want to write data, it fails!
HW Setup
The value you are setting in send_address() function is one bit off. Chip address 0x50 is 7bit number, which has to be shifted 1 bit up when sending on I2C bus (lowest bit is read/write flag). So you should use send_address(0xa0) (that is 0x50<<1) in your code, or do the shift inside send_address() function.
By "when i send the Address+/W, i neither get ACK nor NACK" you mean that your code hangs in while (!(TWCR &(1<<TWINT))); loop inside send_address()? If so, than it is different issue unrelated to the address mentioned above.
    \$\begingroup\$ Thanks! the code does not hang in send_address(). I was sending the address as a 7bit, 1010000, the upper nibble 1010 is fixed, now i get it! It works so far now, i.e i get an ACK in return :) \$\endgroup\$
    – Abel Tom
    Jun 5, 2017 at 9:25
