I am trying to use ADS1252 ADC with Arduino. I got following schematic from git of a breakout board for ADS1252
ADS1252
Now there is only one pin dedicated to input signal whereas I want to use this board in differential input mode.
Questions:
  1. Is it possible to use this circuit in differential mode if I give SIG2 to inverting terminal of U2 ?
  2. why is this configuration of OPAMPs used between SIG and ads1252 input pin?
  • \$\begingroup\$ It looks to me that the ADC is running in diff mode. The input amps you see provide a converting stage to transform a uni-polar single-ended input (~0-5VDC) to a differential input to the ADC. A strategy to boost resolution. This circuit is not designed to accept a differential signal as an input. It may be possible to hack the design if needed (you would need to cut some traces). Do some more googling. \$\endgroup\$ – Chris Knudsen Jun 5 '17 at 21:16
  • \$\begingroup\$ @ChrisKnudsen so it's fairly simple then I just need to connect differential signals to VIN+ and VIN- of ADC. Also about the circuit..Is it for noise reduction ? \$\endgroup\$ – Mr.Sky Jun 5 '17 at 21:19
  • \$\begingroup\$ Also, R5 should not be a 0-ohm resistor. It could however, be a 'none'-resistor :) \$\endgroup\$ – Chris Knudsen Jun 5 '17 at 21:21
    \$\begingroup\$ Re, the circuit as is: No, it is a single-ended to diff converter. It allows one to connect a native single-ended signal to a differential converter. It will help with the resolution of the conversion of the single-ended signal, and that's about it (there is some minor filtering going on, but nothing terribly aggressive). You'll be fine to not implement this circuit, if you already have a true unipolar differential signal (be certain that you do!). A true unipolar differential signal will have two signal wires. The signal on one will mirror the other. Only positive voltages. \$\endgroup\$ – Chris Knudsen Jun 5 '17 at 21:28
  • \$\begingroup\$ @ChrisKnudsen ooh so that's what it for (I thought it was some kind of hardcore noise reduction black magic thing)..... Now I understand it completely !! Thanks, man !!!:) \$\endgroup\$ – Mr.Sky Jun 5 '17 at 21:34
Re, the circuit as is: No, it is a single-ended to diff converter. It allows one to connect a native single-ended signal to a differential converter. It will help with the resolution of the conversion of the single-ended signal, and that's about it (there is some minor filtering going on, but nothing terribly aggressive). You'll be fine to not implement this circuit, if you already have a true unipolar differential signal (be certain that you do!). A true unipolar differential signal will have two signal wires. The signal on one will mirror the other. As one signal goes from 0 to 5, the other goes from 5 to 0. Only positive voltages, and be wise to stay away from either rail, 0 or 5V (Consult the datasheet of the ADC). In addition, there should be a ground reference from your signal circuitry to the ADC ground.
