I am attempting to create a PCB hatch footprint as used on calculators etc with a rubber keypad switch.
I can create a hatched area without any issues:
Which is clearly lovely.
If you look, you'll see that the two ends of the pads are 1 and 2, as per the round pads at the top and the bottom of the footprint.
However, when I try an use it in my PCB layout, Altium complains that the traces are shorted around pad 1, as all the traces are labeled as GND (the net attached to pin 2). I have redrawn this multiple times in multiple ways to try and ensure that the traces are as you would expect.
Is there a way in Alitum to force a set of traces to connect to a pin? Is there a way to check which pin the trace is connected to? What simple thing have I stupidly managed to miss?
