I recently came across the Bit-banding feature on Cortex-M4 core and how it provides a solution to avoid race-conditions while toggling bits of registers. The M4 also has a dedicated BSRR register for performing atomic bit manipulation on the GPIO ports,I understand that using this makes the application thread-safe
Is there any downside to this approach compared to the generally used Read-Modify-Write method of toggling GPIO pins.If not, then why are GPIO_ODR registers provided for the cortex-m cores, why not use only the BSRR register for GPIO pin access.
  • \$\begingroup\$ Take this case: toggling 8 pins(can be a port altogether) at the same time? Which is faster? \$\endgroup\$ – ammar.cma Jun 7 '17 at 10:37
    \$\begingroup\$ @ammar.cma the BSRR/BRR can change up to 16 bits at a time if they are in the same port. But what these registers can't permit is transferring arbitrary data with an efficient fixed instruction. \$\endgroup\$ – Chris Stratton Oct 18 '17 at 6:41
You assume that all operations on IO ports are at bit level. I wrote an external LCD interface a while ago that used Px0..Px7 for the data interface, and Px8 for the write control. This allowed me to directly stream a pixel (16-bit colour) to the display using a sequence of four GPIO_ODR writes. If I had used BSRR I would have had to translate the raw pixel data into bit masks for that register. This would have slowed things down significantly.
You didn't specify the particular MCU in question, but the BSRR register is specific to ST Micro Cortex-M parts.
The BSRR register provides similar functionality to the bit-banding feature that is part of the Cortex-M architecture with regards to atomic operation.
As for whether bit-banding has a downside compared with doing read-modify-write, the main drawback is that they can only manipulate one bit at a time.
    \$\begingroup\$ Note that unlike address-based bit banding, the BSRR and BRR do permit multi-bit operations, as they operate with bitmasks. \$\endgroup\$ – Chris Stratton Oct 18 '17 at 6:38
  • \$\begingroup\$ The GPIO ports that Arm licenses with the Cortex-M have a mask built into the port address, so you can do an atomic write of the port bits with a single operation. The only vendor that I'm aware of that use the Arm GPIO design is TI, although NXP does it in a similar way. Energy Micro/Silabs has ports with set/clear registers. \$\endgroup\$ – Robert Sexton Oct 19 '17 at 4:42
