I'm pretty new to hardware stuff. I have a basic idea to build a hardware controller for some proprietary software. I would need to read about 60 analog faders/potentiometers and 30 buttons. Also I need to drive about 40 LEds. I have Arduino or Raspberry Pi at hand. Up to 60ms delay from mechanical movement to registered value would be ok. I found some digital potentiometer accessible via I2C but at a hefty price (14$ per piece - I'd need about 60 of them)
  • \$\begingroup\$ Can you MUX them? \$\endgroup\$
    – winny
    Jun 7 '17 at 10:32
  • \$\begingroup\$ And what is the question? \$\endgroup\$
    – Andrew
    Jun 7 '17 at 10:32
    \$\begingroup\$ What exactly is your question? Switches put on shift registers to read serially, pots use ADCs, probably with analogue muxes in front of them. \$\endgroup\$
    – Colin
    Jun 7 '17 at 10:32
    \$\begingroup\$ fyi: Regarding last sentence about digital potentiometers. When you say "digital potentiometer" most people will get an image of an output device (digitally controller potentiometer). \$\endgroup\$ Jun 7 '17 at 19:29
  • \$\begingroup\$ Nick, thanks. Terminology is sometimes hard at the beginning. \$\endgroup\$
    – m_c
    Jun 8 '17 at 7:41
Look for multi-channel ADCs to read your pots, chips with 16 or 32 channels are not unheard of. Or use analog muxes as Colin suggested, here's a DIY friendly solution if you're planning to solder by hand.
For buttons and LEDs, you can use multiplexing or shift registers, as described e.g. here.
    \$\begingroup\$ Thanks Dmitry! That is exactly the stuff, I was looking for. It's always hard to create a clear question without knowing the exact terminology, but that lead me in the right direction. \$\endgroup\$
    – m_c
    Jun 8 '17 at 7:35
  • \$\begingroup\$ @m_c Good luck with your project! \$\endgroup\$ Jun 8 '17 at 7:39
