How can I use a capacitor to ring a landline phone over and over again. I assume I need to develop such a circuit like below with a cap placed on one of wires. I think the cap would charge, and when decharging, it can ring the landline phone. If such a scheme is possible, does anybody know how I can calculate the needed capacitance for the cap.
closed as unclear what you're asking by Matt Young, Enric Blanco, Voltage Spike, Dave Tweed Jun 8 '17 at 21:52
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ No, that won't work. The ring voltage supplied by the central office is (if I recall correctly) pulses of about 90 Volt 20 Hz AC. There is no simple way to reproduce that with a few passive components. \$\endgroup\$ – Peter Bennett Jun 8 '17 at 4:08
Putting a capacitor in series with a phone like that will allow it to ring when the "main distribution facitilty" (I'm assuming you mean FXS, central office, or PABX etc) signals a ring but it will not be able to answer or make calls. it will not cause it to ring at other times .
For the capacitor 10uF 100V non-polarised sounds about right.
Some phones may behave strangely in this configuration at they require a DC supply for correct on-hook operation. (eg Alcatel TF200 series)
Now, if you have a phone and want to make it ring you need the 90V AC mentioned in the comments, you can find this on a ringing phone line. or make it using a PABX or FXS adaptor or a ring generator circuit.
