Is there anyway to find a chip part # based only on the mark codes.it says 633 then below it says MV.from the circuit it seems to be a cap at 2.2uF. any help is appreciated thanks.
\$\begingroup\$ The service manual of the device that thing on is the best tool. All else is pure guesswork. Maybe a photo makes people recognize it. If its a cap, the part number isn't really important, also if its one the value is printed on it (63nF would be more plausible then) \$\endgroup\$ – PlasmaHH Jun 12 '17 at 13:44
For some devices there is the SMD Codebook - however there are so many new SMD devices coming out all the time it's impossible for it to be kept up to date. It's often good for things like SMD transistors, but rarely for chips.
As mentioned the service manual / schematic for the unit you are working with is the only sure-fire way of knowing exactly what it is.
Identifying the package can also narrow things down somewhat - for instance a capacitor will only ever be in a small number of packages and be instantly identifiable (unless it's a black tantalum capacitor that looks just like a diode, when it can be confusing). So a picture of the device posted on this site (you'll see there are a lot of "what is this component?" questions around) can get you moving in the right direction.
\$\begingroup\$ ok let me see if i can get a good picture of it then thanks for both of the replies \$\endgroup\$ – T. A. Jun 13 '17 at 0:11
\$\begingroup\$ i started a new thread with more details on what it is electronics.stackexchange.com/questions/310710/… \$\endgroup\$ – T. A. Jun 13 '17 at 14:46
