In the following question, they ask for the frequency at which the gain would be 1.41 V/V. The dc or low frequency closed loop gain is 2V/V (6 dB). Is the solution of the following question done correctly? I think it is wrong as they get the answer for frequency to be 5MHz, while 5Mhz is the closed loop 3db frequency of the amplifier. The frequency resulting in 1.41 V/V gain aught to be larger than that. Please tell me if their solution is correct or not and if it is not then what is the correct one?
1\$\begingroup\$ The answer looks good for me (6dB - 3dB = 3dB = 1.41 V/V) \$\endgroup\$– G36Jun 12, 2017 at 17:43
1\$\begingroup\$ Possible duplicate of electronics.stackexchange.com/questions/200665/…. Answer looks correct. \$\endgroup\$– Spehro PefhanyJun 12, 2017 at 17:48
\$\begingroup\$ The question is asking for frequency. What r u talking about? \$\endgroup\$– Moeen AhmedJun 12, 2017 at 17:49
