I am having confusion over what value the output waveform will take when the input voltage has negative half cycle (so that diode is reverse biased). In my intuition, the diode acts as open circuit and output voltage should be 2V. And during positive half cycle, the output voltage is still 2V for Vin < 2V(as diode is still reverse biased) and then follow Vin for all other values of Vin.
The problem is that I don't get the same answer as my textbook depicts. My answer looks something like this: Sorry for the rough figure. Please consider it.
Is this the correct way, or am I wrong?
Edit: The Texbook says: enter image description here
  • \$\begingroup\$ What does the textbook predict? \$\endgroup\$ – Kevin White Jun 13 '17 at 2:57
  • \$\begingroup\$ Kevin White, Just edited the question with the answer from textbook. \$\endgroup\$ – bikalpa Jun 13 '17 at 3:06
  • \$\begingroup\$ I agree - they've got the answer wrong. It would give that if the diode was reversed. Your answer is right. \$\endgroup\$ – Kevin White Jun 13 '17 at 3:11
You're right! I added a function generator to the input of your circuit, and then plotted V(in) and V(out). Take a look at this quick simulation:
The result matches your sketch, not the textbook's answer.
