-1
could anyone explain, why the output signal in my verilog testbench isn't changing?
I'm trying to build a module that does tasks on both posedge and negedge.
For testing purposes, I've built a module that receives a clock and returns one signal.
The signal is being set to 1 on posedge, and set to 0 on negedge- I expect it to be a copy of clock signal.
Everything is compiling and synthesizing without errors, the testbench is being run- but the output signal doesn't change, it stays at zero.
I am new to verilog, so maybe I'm missing something obvious.
Here is my module-
module mytest( clk, rst, led );
input clk, rst;
output led;
reg r_out = 1'b0;
always @ (*)
begin
    @(posedge clk)
    begin
        r_out <= 1'b1;
    end
    @(negedge clk)
    begin
        r_out <= 1'b0;
    end
end
assign led = r_out;
endmodule
And here is the testbench-
`timescale 1ns/100ps
module mytest_tb;
parameter SYSCLK_PERIOD = 100;// 10MHZ
reg SYSCLK;
reg NSYSRESET;
wire w_led;
// Clock Driver
always @(SYSCLK)
    #(SYSCLK_PERIOD / 2.0) SYSCLK <= !SYSCLK;
// Instantiate Unit Under Test:  mytest
mytest mytest_0 (
    // Inputs
    .clk(SYSCLK),
    .rst(NSYSRESET),
    // Outputs
    .led(w_led)
    // Inouts
initial
begin
    SYSCLK = 1'b0;
    NSYSRESET = 1'b0;
end
endmodule
Thanks in advance!
  • \$\begingroup\$ For synthesis, you cannot have @(*), @(posedge clk) and @(negedge clk) in the same always block. I'd expect an error for this; if not, there should at least be warnings. There must only be one @ and it needs to next to always. \$\endgroup\$ – Greg Jun 13 '17 at 15:01
  • \$\begingroup\$ @toolic - I chose a bad example. The question is not about copying clk signal, it's about modifying register on both posedge and negedge. Thanks anyway! \$\endgroup\$ – Karlis I. Jun 14 '17 at 14:17
  • \$\begingroup\$ @greg - I was told that my approach is wrong. I'll clarify with some more people and report here. \$\endgroup\$ – Karlis I. Jun 14 '17 at 14:19
So, I was pointed out that this is a wrong approach.
The problem in question should have been solved by using a Finite State Machine- that would eliminate the need for additional actions on negedge.
As for the question itself- why doesn't the test work- that's because
always @ (*) begin
    @ (posedge clk)
    @ (negedge clk)
end
is incorrect syntax. Correct would be
always @ (posedge clk) begin
end
always @ (negedge clk) begin
end
| improve this answer | |
