I am creating a device with multiple variants in EAGLE. The associated symbol should show the variant as well, so that it will be directly visible on the schematic.
I know how to add e.g. >VALUE or >NAME to a symbol and how to show attributes, too. But I can't find a way to show the variant name.
  • \$\begingroup\$ What is variant in your understanding? There're two things - technology and package, are you talking about package? \$\endgroup\$
    – Anonymous
    Commented Jun 13, 2017 at 13:07
  • \$\begingroup\$ @Anonymous : In the device screen you can add multiple packages. Each time you add one, a variant is created, which can be named. E.g. a microcontroller variant with same package and pinout but more memory. Maybe I could use the technology field for this as well, but it would be more work to provide the attribute information eacht time. \$\endgroup\$
    – Grebu
    Commented Jun 13, 2017 at 13:19
I think names speak for themselves, but anyway let's look into them. For this just open 74-xx-little-us.lbr in the library editor and then device 74*1G00 as an example.
  • Package: you already know that it is footprint of the device on the board;
  • Variant: the identification of the package in relation to the current device;
  • technology: the intrinsic capability of the device.
Go to schematic editor, and import 74AHCT1G00DBVfrom the list of 74*1G00 from this 74-xx-little-us.lbr library.
This name 74AHCT1G00DBV is composed in the following way:
  • 74*1G00;
  • AHCT put instead of * as technology;
  • DBV is added at the end as variant.
Now look into the library editor again. Right click onto package/variant line in the subwindow to the right, you will see that:
  • you can rename this selected variant (in other words, change package suffix);
  • you can add, remove or assign technologies for the device available in this selected package (variant).
In your example with microcontroller, which may have different RAM size:
  • create symbol for it, all packages/technologies/variants will have same symbol;
  • create packages this MCU is available in, add them to the list in library editor, for example N for DIP and D for SO;
  • add each package twice to the device, give each package in library editor's package/variant subwindow unique package identification, e.g. "KN" and "KD" for 16 KB RAM, and "YN" and "YD" for 32 KB RAM;
  • create technologies available, for example "42" for 3.3 V, and "46" for 5 V device;
  • name device as PIC*K22.
And in schematic editor you will have the following devices in the list available (of course depending on your technology assignments)
PIC42K22KN
PIC42K22KD
PIC42K22YN
PIC42K22YD
PIC46K22KN
PIC46K22KD
PIC46K22YN
PIC46K22YD
which will represent complete device identification marking.
The example above is (almost) out of the blue, because I like Microchip :)
(hopefully I did not make any logical mistake above, and I am sure you will figure out things yourself).
  • \$\begingroup\$ That helped my understanding a lot! Your solution will show up in the value field of the symbol then. Is there another option to show the devicename on the symbol? I would like to use the value field for e.g. resistance values too. \$\endgroup\$
    – Grebu
    Commented Jun 13, 2017 at 16:06
  • \$\begingroup\$ You already know >NAME keyword (in the Names layer) and >VALUE keyword (in Values layer). Resistor device, most probably, is already having its >NAME field defined, but it is just empty. Open info window on the resistor device in schematic editor, and define its value. \$\endgroup\$
    – Anonymous
    Commented Jun 13, 2017 at 16:43
