Couldn't make up my mind :P
Characteristics:
12V-80V Vin (DC)
3.3V system
In general terms (considering architecture and design) is it better to do directly 3.3V from Vin or is it better to do some intermediate step in between before having 3.3V for IC-s (say 12V and then 3.3V OR 5V and then 3.3V)?
I have an option to get all my components to run on 3.3V. I have one cheap 5V tranceiver (3.3V IO compatible btw), but I find it pointless to have a 5V rail JUST because of it, when everything else is 3.3V. I can find the tranceiver in 3.3V as well.
But also I find buck converting 60Vin-max to 3.3V kind of a big step (low duty cycles, bigger components...) But having intermediate step without using it seems also a waste (extra components).
This is really two questions I think, a dedicated 5V rail question, and a large DCDC step, so I'll try and answer them each.
Dedicated 5V rail There are advantages to having a dedicated rail for some devices some times. But they are high noise, or high sensitivity areas. Keep it all at 3V3 and you'll find it easier. The only other time to have a dedicated power supply is to simplify layout/routing, but your system doesn't sound like it's complicated enough for that to be a concern.
Big step of 60 to 3V3 I would say this is less of an issue than you think. While it could be noisy, having only one switcher means you can control the output and the input to it should be simple. Putting two switchers back to back can get complicated with noise, as they each could effect each other which could make noise better or worse depending on so many factors. No idea if cost is important, but it is almost always cheaper to have one switcher to do it all, as this also means less passives etc.
Another way to look at it is losses: two switchers will each have their own losses, it may not be double the losses, but will be more than just having one supply. If you have a power draw of 100mW, with two switchers, each at 90% efficient, you're getting 81mW at the components. Meanwhile if you only had one switcher, you'd be getting 90mW.
A single step change would be best.
| improve this answer | |
