This question already has an answer here:
Typically it is a three bare pin polarized connector, with power, ground and tacho connections. However, I am having difficulty finding it as a part. What is it called?
This is what I am trying to connect to enter image description here
marked as duplicate by Passerby, Wesley Lee, Voltage Spike, Community Jun 14 '17 at 15:16
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
That connector would be called something along the lines of "4 pin cable header" where it is important to know the connector pitch. I can't quite determine pitch from that picture but common industry standards are 2.0mm, 1.27mm, 1.25mm, 1.0mm.
Its mate would be called something like "4 pin x mm socket header". You should search for board-to-wire connectors. Likely, one of these will be the one:
http://www.molex.com/molex/products/group?key=wire_to_board_connectors&channel=PRODUCTS&langPref=english
    \$\begingroup\$ And 2.54mm, which is the actual pitch on PC Fan headers. \$\endgroup\$ – Wesley Lee Jun 14 '17 at 14:51
  • \$\begingroup\$ At the serious risk of stating the obvious, 2.54mm = 0.1" or about 1/10 the width of a man's thumb. \$\endgroup\$ – Spehro Pefhany Jun 14 '17 at 17:04
  • \$\begingroup\$ @WesleyLee Still 2.54 today? I would find it too big to even consider for such an application. Or is that just old computers? \$\endgroup\$ – Lundin Jun 15 '17 at 6:41
  • \$\begingroup\$ @Lundin -- yep, although I don't think its a bad thing that they didnt change the standard. \$\endgroup\$ – Wesley Lee Jun 15 '17 at 16:44
The connectors used for computer fans such as the one pictured are 3-pin Molex KK 2.54mm pitch or compatible.
Newer motherboards use a 4-pin variant with a modified notch to allow for backward compatibility with the older 3-pin standard. Most PC fans still use a 3-pin connector though.
