15
Looking on Digikey there are ~1300 results for 5.1V Zener diodes compared to 6 for 5V ones.
Is there any physics-related reason for this or is it something else?
  • 31
    \$\begingroup\$ You get a bonus 100 mV for the same price. \$\endgroup\$ – Olin Lathrop Jun 15 '17 at 11:12
    \$\begingroup\$ Avalanche diodes have a positive temperature coefficient of voltage, zener diodes have a negative coefficient. Near 5.1V the zener effect and the avalanche breakdown effect are close to equal, and the temperature coefficients cancel somewhat. \$\endgroup\$ – Dietrich Epp Jun 15 '17 at 12:31
  • \$\begingroup\$ @OlinLathrop: Yes, but in exchange for that 2% boost in voltage, you take a 2% hit on the current handling ability at a given power dissipation. \$\endgroup\$ – Dave Tweed Jun 15 '17 at 13:58
    \$\begingroup\$ @DietrichEpp: I was under the impression that the cancellation occurred closer to 5.6V, which is fortuitous, since such a zener followed by an emitter follower then delivers almost exactly 5.0V. This may even be one reason why 5V was chosen as the standard supply voltage for digital logic so many decades ago. \$\endgroup\$ – Dave Tweed Jun 15 '17 at 14:05
17
Zener diode voltages largely follow the E24 resistor value intervals, a range of a intervals specified with +/-5 % accuracy.
Zener diodes have not particularly developed as a technology, with accurate voltage references using bandgap techniques instead. The intervals have stayed the same for many years.
As an aside, Zener diodes are less commonplace in circuits than may be expected to electronics newcomers, who can sometimes regard them as appealing 'magic voltage drops'. Their combination of basic inaccuracy, notable variance with temperature and current and a fairly large working current for stability lessens their usefulness compared to other design approaches and components.
  • 6
    \$\begingroup\$ Perhaps worth noting that while the absolute accuracy of a zener is far less than that of a bandgap, in general, their long-term stability and such is far superior, making them the go-to device for high-accuracy systems that rely on trimming to get the initial accuracy right (LM199/LM399/LTZ1000). \$\endgroup\$ – Joren Vaes Jun 15 '17 at 11:50
13
Well, like resistors and capacitors, zener diode voltage values tend to follow a range of preferred numbers such as: -
So, quite often you'll find 4.3 volt, 4.7 volt, 5.1 volt, 5.6 volt zener diodes etc..
As an aside, the 5.1 volt zener diode in several supplier ranges has the lowest temperature coefficient of voltage change with temperature: -
So, if you had asked why a lot of designs use 5.1 volt zeners I would say it is down to physics.
As Andy said, the available zeners are forced into the E24 series, like other components. This is done by fiddling with the physics- lower voltage (less than about 5V) are actually Zener diodes, and higher voltage diodes are avalanche diodes. The avalanche diodes work a lot better (in terms of having a sharp voltage-current 'knee'). Here are some characteristic curves from Onsemi that show the variation of characteristics with zener voltage (which they show as a continuous variable): enter image description here
Note that zener impedance is plotted on a lot-log graph- the impedance of a ~3V zener at 5mA is about 80 ohms, whereas that of a 10V zener is more like 8 ohms. So if we use a 400 ohm resistor on the former (from a 5V supply). If we similarly use a 16.7V supply and a 10V zener with 1.33K in series, the percentage regulation is more than 25x better with the latter. So lower voltage zeners are pretty useless.
There is one niche where the zener voltage that is picked is based on physics, and on the above characteristics - and that is for voltage references. For many applications band-gap references have replaced zeners- they have many advantages, especially for non-critical applications- low power and low voltage operation etc. They are noisy and have other disadvantages, however those have gradually been addressed.
Some of the very best component references were a zener diode with an integrated series diode to effectively zero out the temperature coefficient of voltage. This combination only works at a single voltage/current combination- about 6.2V or 6.55V, so the underlying +2mV/degree C zener is about 600mV less than that. An example of these parts is the 1N829.
Those devices, while very stable, are less popular these days, partly because they cannot be trimmed so the voltage tolerance cannot be made extremely tight. Modern bandgap references with trimmed resistors can be made to very tight tolerances. Stability may not be as good as the zener though.
Some of the very best references available are still integrated Zener diodes (subsurface "buried" zeners with added temperature compensation and trimming, often in ovenized form). An example of that is the LTZ1000, probably the best commonly available reference in terms of tempco and stability (albeit expensive, power hungry and a bit needy in other areas).
    \$\begingroup\$ One day I shall use one of those LTZ1000A devices. They just need fiddling with in terms of raw output voltage not being particularly allied to a consistent and sensible number. TempCo is awesome though. \$\endgroup\$ – Andy aka Jun 15 '17 at 14:57
    \$\begingroup\$ @Andyaka They're pretty awesome but you need a bunch of $15 resistors etc. to do them justice. \$\endgroup\$ – Spehro Pefhany Jun 15 '17 at 15:02
  • \$\begingroup\$ Yeah, that's why I still use the LTC6655 - it's just all virtually there and no quibbles! \$\endgroup\$ – Andy aka Jun 15 '17 at 17:09
  • \$\begingroup\$ @Andyaka There's another reason to use the LTC6655 in some circumstances but I can't discuss in a public forum. \$\endgroup\$ – Spehro Pefhany Jun 15 '17 at 17:45
Zener Diodes tend to follow E24 series like Andy aka stated.The stated device to device tolerance of garden variety Zeners is 5% .When variations in temp and Zener current are factored in things can get a lot worse than 5% .The difference between 5V and 5v1 is only 2% .If you tested two bags of say 10 zeners that were bag A 5V and bag B 5V1 you might not be able to tell which bag was which .The same reasoning applies with 5% resistors.
