-1
I have a 5V 5A DC power supply. From this power-supply I want to power 6 seperate 5V devices, which aren't connected in any way except the common power-line. My understanding is that I simply can divide the cables. Is there any hardware for doing so ("split clamps" or something like that)? How would you do it? I don't have that much space - so a small solution would be great.
closed as off-topic by Voltage Spike, Enric Blanco, PeterJ, DoxyLover, Dmitry Grigoryev Jun 19 '17 at 10:50
  • This question does not appear to be about electronics design within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Splice the cable, use terminal connectors a terminal block or how ever else you would connect 7 conductors. \$\endgroup\$ – Voltage Spike Jun 15 '17 at 15:21
  • \$\begingroup\$ Are you familiar with parallel / in series connections? You may want to google that first. \$\endgroup\$ – Dmitry Grigoryev Jun 19 '17 at 10:49
There are plenty of clamps out there to split wires. I've seen twist-on clamps (but never used them), "wago" clamps, distribution strips, etc. There is also solder, but solder is often discouraged to use in cable-to-cable connections, as it causes a point of stress. General splicing is to my knowledge better.
Ofcourse, I hope it is evident that you need to put the 6 devices in parallel, not in series. If this is not obvious, perhaps it's worth taking a step back and looking up some basic material on series/parallel and Ohm's law before you start.
Without more information, it's hard to provide a more specifict solution.
