I've come across a circuit I'm not too familiar with:
enter image description here (Goggle Drive version)
How do I tune R1, R2, R3, and C1 to adjust frequency and duty cycle?
I get the general idea of how it works, but I've asked 4 engineers that I work with already, and the only answer I get is "That's an old school approach, ask the other guy". I'd like a better understanding of how this circuit works - Any help would be appreciated.
    \$\begingroup\$ Remember this circuit will only work if your first NAND gate has Schmitt trigger inputs. \$\endgroup\$ – Doodle Jun 15 '17 at 14:42
  • \$\begingroup\$ @Doodle it does not have them but the circuit works. Just not sure how to tune it. \$\endgroup\$ – Jedi Engineer Jun 15 '17 at 15:15
  • \$\begingroup\$ I'm not quite sure how your circuit works without schmitt trigger inputs. Your output should be flickering all over the place using something like a 74HC00. Transistors answer tells you how to tune it exactly. \$\endgroup\$ – Doodle Jun 15 '17 at 15:27
  • \$\begingroup\$ That's two of us. Which is why I posted... \$\endgroup\$ – Jedi Engineer Jun 15 '17 at 17:12
Initial conditions:
  • C1 discharged so NAND pin 4 is high.
  • This feeds back to AND pin 1 and since 2 is permanently high AND pin 4 goes high charging up C via the parallel paths of (R1 and diode) and R3.
  • When C1 voltage is high enough NAND pin 4 goes low.
  • AND pin 1 now goes low and C discharges through R3 only.
  • Repeat.
The diode makes the waveform asymmetric. C charges through R1 and R3 but can only discharge through R3.
  • C1 charge-up time, \$ \tau_1 \$, will be given approximately by the time constant \$(R1 || R3) \times C\$. (where "||" is the parallel resistor value.)
  • The discharge time, \$ \tau_2 \$, by \$R3 \times C\$.
  • The total period of each cycle will be \$ {\tau_1 + \tau_2} \$.
  • The frequency will be \$ \frac {1}{\tau_1 + \tau_2} \$.
  • The duty cycle will be \$ \frac {\tau_1}{\tau_1 + \tau_2} \$.
  • The diode introduces a further slight complication in that there is a voltage drop across it. The effect seems to have been minimised by using a Schottky diode which has a lower voltage drop than a regular silicon diode.
The \$V_{IH} \$ level is 3.5 V, and the \$V_{OL} \$ level is 1.6 V. How does that change the equation?
It doesn't. I assumed the thresholds would be about those proportions.
Going from low to high C will initially be at 1.6 V and the charging voltage close to 5 V. Switching will take place at 3.5 V which is \$ \frac {3.5 - 1.6}{5 - 1.6} = 56\% \$ of the way to fully charged. You can see from Figure 1 that this is quite close to the 63% value of one RC time constant, \$ \tau \$.
Going from high to low C will initially be at 3.5 V and the discharging voltage close to 0 V. Switching will take place at 1.6 V which is \$ \frac {3.5 - 1.6}{3.5} = 55\% \$ of the way to fully discharged. This time you can see from Figure 1 that this is not close to one time constant, \$ \tau \$ but probably good enough.
Don't forgot that you will have variation from chip to chip.
Figure 1. RC charge / discharge curve.
Furthermore, what role does R2 play? I was presuming there was some discharge through it, at one point at least....
On power-off the NAND gate will have no supply. C will discharge through the input protection diodes and will try to power up everything on the PCB that's connected to that power rail. R2 limits that current to a value that the protection diodes can handle. In normal operation it has no effect on the timing because the NAND inputs have such high impedence - typically GΩ.
  • \$\begingroup\$ Thanks for the edits, Andrew. Too much of a hurry, I'm afraid. \$\endgroup\$ – Transistor Jun 15 '17 at 14:23
  • \$\begingroup\$ I recommend you wait a day or so before accepting the answer. You might get a better one. \$\endgroup\$ – Transistor Jun 15 '17 at 16:06
  • \$\begingroup\$ if I only had the time... lol \$\endgroup\$ – Jedi Engineer Jun 15 '17 at 17:04
  • \$\begingroup\$ Besides, it's locked. I can't uncheck it if I wanted to. Let's see what pops up. \$\endgroup\$ – Jedi Engineer Jun 15 '17 at 17:10
  • \$\begingroup\$ let me throw a cog in the works - these are 5V parts, and the VIH level is 3.5V, and the VOL level is 1.6V. How does that change the equation? Or do I need the exponential function for this? \$\endgroup\$ – Jedi Engineer Jun 15 '17 at 17:12
