I have a 302 telephone that was manufactured in 5/39 (May 1939). The line cord does not have a four-prong connector attached; the wires are simply cut.
I am trying to get this connected. I have a four-wire RJ11 cable with both tip and ring (red and green) as well as yellow and black. The 302 has only green, red, and black.
I don't really have the equipment needed for stripping cables, nor do I want to. I am attempting to make a head on connection, like so:
The three wires
The yellow wire is hidden behind the green cable. The twistie ties are just to keep the individual copper wires together and straight. What I would like to do is be able to simply attach the three sets of wires to the RJ11 connector, and maybe tie it together with a larger twistie tie.
Currently, the interior of the telephone seems operational. There is only one unconnected wire as far as I can see, by the rectangular gray thing.
302 Telephone internals
I have been looking at several wiring schematics. One person said to connect green to green and red and yellow to red. A YouTuber had similar advice for a 500. But this was to connect to a two-wire RJ11 cable, and I have a four-wire RJ11 cable here.
I think ideally one would strip the RJ11 cable and then tape the right sets of wires to the wires in the RJ11 cable, but I'm not going to do that. I have been testing various combinations of colors, including G to G and R/Y to R. At the same time, I've been holding the receiver up to my ear but I am not getting a dial tone. The RJ11 cable is a live wire.
Does the wiring combination really matter? Will it not work if the combination is wrong? The wiring inside looks okay, so it's hard to isolate the problem.
The wiring in my 302 does not seem to be the same as the diagram in the answer:
Wiring of the 302
Could the red wire that is disconnected be causing a problem? Red is RING, so will it stop me from getting dial tone also?
When I did tip and ring to tip and ring it did not work:
Tip and ring wire connections
    \$\begingroup\$ You really can't expect to hold the wires on to the RJ11 and have it work. \$\endgroup\$
    – JRE
    Jun 15, 2017 at 17:02
    \$\begingroup\$ Either get a connection block as Spehro Pefhany says, or else get out your pocket knife and strip the wires on the RJ11 cable. \$\endgroup\$
    – JRE
    Jun 15, 2017 at 17:07
    \$\begingroup\$ You strip the outside insulation that covers all the wires together, then you strip the individual wires. \$\endgroup\$
    – JRE
    Jun 15, 2017 at 17:53
    \$\begingroup\$ Yeah, so. How's that a waste if you are using the telephone? You could also cut the cable somewhere in the middle and reconnect the two halves if you need it again. \$\endgroup\$
    – JRE
    Jun 15, 2017 at 18:27
    \$\begingroup\$ No cables aren't free. But, you can reconnect the two halves just as easily as you connected your phone to one half. Twist and tape if you can't solder. Anyhow, enough of this. If a telephone patch cable breaks the bank, you've got more problems than I feel like dealing with. \$\endgroup\$
    – JRE
    Jun 15, 2017 at 18:33
North American RJ11 cords can carry two phone lines. Red and Green are the wires normally used, with the outer yellow and black as the secondary. You would only use one pair, and not connect to the other.
Your phone diagram from here:
Green is TIP on the RJ11
Red is RING on the RJ11
So Red to Red, Green to Green.
Yellow should be grounded, according to the the diagram above. You can try the ground on an outlet box for the ground.
It's easier to wire (the question in your title!) if you can get a connection block like this one (preferably without the split plastic boss shown in the photo):
  • \$\begingroup\$ See the diagram above. Yellow apparently needs to go to ground. \$\endgroup\$ Jun 15, 2017 at 15:47
  • \$\begingroup\$ I looked at the diagram. I'm not sure what you mena by ground. Ground is for electrical, not telephone. I have 6 other telephones and none of them are grounded (they are all modular though). I don't know why I would do that with this. Can I just leave yellow out? Does it hurt to connect to green? Thanks, \$\endgroup\$ Jun 15, 2017 at 15:57
  • \$\begingroup\$ I don't know what you mean by split plastic boss. Would this be alright? ebay.com/itm/172535143317 \$\endgroup\$ Jun 15, 2017 at 16:01
    \$\begingroup\$ Yes, the ebay one looks the same. The one in my photo is broken from overtightening the screw for black. \$\endgroup\$ Jun 15, 2017 at 16:03
    \$\begingroup\$ In ancient times, with party lines (two customers sharing the same line), one customer's ringer would be connected between Tip and Goround, the other customer's between Ring and Ground. Fr single-customer lines the ringer is connected between Tip and Ring. \$\endgroup\$ Jun 15, 2017 at 16:27
