The equation is:
\$I_{in} = \frac{V_{th} - V_{in}} { R_{th}}\$
This equation is from a one-port network.
Variables:
I = input current
Vth = thevenin voltage
Vin = input voltage
Rth = thevenin resistance
  • \$\begingroup\$ Where is the schematic? \$\endgroup\$
    – dirac16
    Jun 15, 2017 at 23:50
  • \$\begingroup\$ @dirac question edited. \$\endgroup\$
    – 21rw
    Jun 15, 2017 at 23:55
    \$\begingroup\$ You added a single line, without a schematic. What did you miss about "where is the schematic"? \$\endgroup\$
    – Jashaszun
    Jun 16, 2017 at 0:10
  • \$\begingroup\$ @Jashazun I'm sorry. Reedited the question. \$\endgroup\$
    – 21rw
    Jun 16, 2017 at 0:14
Here's the equivalent circuit in the situation you're asking about
"X" is whatever device is outside the device being studied. It could be a source, a resistor, or anything else.
Regardless of what is connected to the port, if the input voltage is \$V_{in}\$, then you can see the voltage across the thevenin equivalent resistor is \$V_{in}-V_{th}\$, so the input current can be obtained from Ohm's law as
$$\frac{V_{in}-V_{th}}{R_{th}}.$$
Which, incidentally, means there is a sign error in the formula you presented.
