6
For 3D CAD modeling, there is software called OpenSCAD which allows you to create 3D designs purely in code and then render them.
I'm wondering if something similar exists for PCB design where I could "write" a PCB, and then compile it to gerber files or similar which could then be sent to a fab site like easyEDA.
Edit: I should specify that by "in code", I mean in some language with support for things like named constants, functions, looping, etc. For example, in OpenSCAD, I can do things like
  for(i = [0 : num_planks-1]) {
       translate([i * plank_w, bb_w, top_height]) cube([plank_w, plank_l, top_thickness]);
and so by changing constants, I can quickly alter the parameters of a model.
What I'm trying to do is create a pcb for a keyboard, but I'd like to be able to easily tweak the layout without having to shuffle each keyswitch around by hand. Adding or removing a row of keys, changing the staggering of the rows, etc. It seems like these sorts of things could be easy if the board was properly described in code rather than in a graphical editor.
  • 7
    \$\begingroup\$ You could write Gerber directly; or you could use one of the SVG->PCB format converters. Avoiding manual routing entirely is .. optimistic. \$\endgroup\$
    – pjc50
    Jun 18, 2017 at 19:07
10
Though EAGLE is a graphical editor, it can be controlled entirely via command line, which is the single input line above the drawing area. The commands can also be written to a script file, and though I haven't looked for it, it is for sure possible to start EAGLE from the operating system's command line and tell it to run the script and then do a CAM job to generate the Gerber files.
This is the layout of the well known simple astable multivibrator:
and this is a (cleaned-up) script which would draw it. (I've drawn it and exported it via the export-board.ulp from here):
GRID INCH 0.005
ADD 'C1' C025-024X044@rcl R0.000 (0.300 0.700);
ADD 'C2' C025-024X044@rcl R0.000 (0.600 0.700);
ADD 'GND' P1-13@testpad R0.000 (1.000 0.150);
ADD 'R1' 0204V@rcl R90.000 (0.100 0.750);
ADD 'R2' 0204V@rcl R90.000 (0.350 0.900);
ADD 'R3' 0204V@rcl R90.000 (0.550 0.900);
ADD 'R4' 0204V@rcl R90.000 (0.800 0.750);
ADD 'T1' TO92@transistor R270.000 (0.800 0.400);
ADD 'T2' TO92@transistor R270.000 (0.100 0.400);
ADD 'VCC' P1-13@testpad R0.000 (1.000 0.950);
LAYER 20
WIRE 0.000 (0.000 0.000) (1.187 0.000);
WIRE 0.000 (1.187 0.000) (1.187 1.100);
WIRE 0.000 (1.187 1.100) (0.000 1.100);
WIRE 0.000 (0.000 1.100) (0.000 0.000);
LAYER 1
SIGNAL 'N$1' R1 1 C1 1 T2 3;
WIRE 'N$1' 0.016 (0.100 0.450) (0.100 0.700);
WIRE 'N$1' 0.016 (0.100 0.700) (0.250 0.700);
SIGNAL 'N$2' C1 2 R2 1 T1 2;
WIRE 'N$2' 0.016 (0.350 0.850) (0.350 0.700);
LAYER 16
WIRE 'N$2' 0.016 (0.875 0.400) (0.450 0.400);
WIRE 'N$2' 0.016 (0.450 0.400) (0.350 0.500);
WIRE 'N$2' 0.016 (0.350 0.500) (0.350 0.700);
LAYER 1
SIGNAL 'N$3' R3 1 C2 1 T2 2;
WIRE 'N$3' 0.016 (0.550 0.850) (0.550 0.700);
WIRE 'N$3' 0.016 (0.175 0.400) (0.450 0.400);
WIRE 'N$3' 0.016 (0.450 0.400) (0.550 0.500);
WIRE 'N$3' 0.016 (0.550 0.500) (0.550 0.700);
SIGNAL 'N$4' C2 2 R4 1 T1 3;
WIRE 'N$4' 0.016 (0.650 0.700) (0.800 0.700);
WIRE 'N$4' 0.016 (0.800 0.700) (0.800 0.450);
SIGNAL 'N$5' R1 2 R2 2 R3 2 R4 2 VCC TP;
WIRE 'N$5' 0.016 (0.100 0.800) (0.100 0.850);
WIRE 'N$5' 0.016 (0.100 0.850) (0.200 0.950);
WIRE 'N$5' 0.016 (0.200 0.950) (0.350 0.950);
WIRE 'N$5' 0.016 (0.350 0.950) (0.550 0.950);
WIRE 'N$5' 0.016 (0.550 0.950) (0.800 0.950);
WIRE 'N$5' 0.016 (0.800 0.950) (1.000 0.950);
WIRE 'N$5' 0.016 (0.800 0.800) (0.800 0.950);
SIGNAL 'N$7' T2 1 T1 1 GND TP;
WIRE 'N$7' 0.016 (0.100 0.350) (0.100 0.250);
WIRE 'N$7' 0.016 (0.100 0.250) (0.200 0.150);
WIRE 'N$7' 0.016 (0.200 0.150) (0.800 0.150);
WIRE 'N$7' 0.016 (0.800 0.150) (1.000 0.150);
WIRE 'N$7' 0.016 (0.800 0.350) (0.800 0.150);
One could simplify this, but yet, that's something for someone with way too much time...
  • \$\begingroup\$ Thanks for your response sweber - I should have given more detail in my original question (I have updated it), but I was hoping for sort of a more powerful scripting language with looping constructs and the like - in any case, it looks like it wouldn't be too difficult to generate this kind of script, so thanks for the example! \$\endgroup\$
    – Matt
    Jun 24, 2017 at 16:45
  • \$\begingroup\$ @Matt: Eagle has a built-in scripting language with a C-like syntax, it's called ULP. See the various ULP programs delivered with your Eagle installation. \$\endgroup\$
    – Janka
    Jun 24, 2017 at 16:51
SKiDL
"SKiDL ... lets you compactly describe the interconnection of electronic circuits ... The resulting Python program performs electrical rules checking for common mistakes and outputs a netlist that serves as input to a PCB layout tool." -- https://github.com/devbisme/skidl (was: SKiDL https://github.com/xesscorp/skidl/ )
"SKiDL ... turns Python into a language for building schematics. It changes circuit design from a fiddly drawing exercise into a programming task." -- https://xess.com/blog/are-you-in-an-abusive-relationship-with-your-schematic-editor/
JITX
"JITX users write code to generate designs so hardware developers can get all the benefits of modern software development: speed, reuse, and automated testing (along with actual version control). ... JITX lets you write arbitrary code to generate, optimize and analyze designs, and export them to CAD (KiCAD and Altium right now...)" -- https://www.jitx.com/blog/faq
pcbflow
"pcbflow - Python PCB layout and design ... pcbflow is best used as a companion to SKiDL. SKiDL is a python based tool which allows you to script the design of electronic circuits." -- https://github.com/michaelgale/pcbflow
Related:
  • James Newman initially designed a relay CPU at a very high-level in a general-purpose language (C++), and (like Matt, the OP) wishes there was a tool to automatically translate it to a schematic, or at least to automatically check that the schematic is consistent with the high-level description. (He ended up manually translating and manually checking, and then endlessly worrying that he'd introduced inconsistencies and errors). https://www.megaprocessor.com/GBU_sw_structure.html
  • "KiCad Third-Party Tools" https://github.com/devbisme/kicad-3rd-party-tools mentions several tools for translating between KiCad schematic format and other schematic formats used for circuit simulation and circuit analysis.
