I would like to find out the internal resistance Ron of this IGBT device : http://www.infineon.com/dgdl/Infineon-IHW50N65R5-DS-v02_04-EN.pdf?fileId=5546d461464245d30146ae23713f0115
The Ron resistance is not included in the datasheet.
Is there a way to export Ron from the charts that are included ?
Thanks in advance
It's not a MOSFET, it is an IGBT, so doesn't have an Ron resistance in the way a MOSFET does.
An IGBT functions like a combined device with a low power MOSFET driving a bipolar transistor. Because the operating current density for bipolar transistors is higher than FETs an IGBT can carry higher currents than the same size FET.
Simplified equivalent circuit of IGBT
The data sheet gives the voltage drop at specific currents and has a curve in figure 5 on page 8 that could be used to determine the voltage drop at various currents. Notice that it does not intersect at zero as a MOSFET would and requires about 0.5v to start conducting.
The Simulink model treats the IGBT DC output characteristic as having two segments:
1) Vf - The voltage at which conduction starts
2) Ron - The slope of the conduction after that point
Simulink IGBT model
From the curve the Vf is 0.5V.
To calculate Ron draw a straight line through the curve from 0.5v to 2.5v. The current increases by ~140Amps over this 2V range. This is equivalent to a resistance of 2/140 = ~14mOhm (0.014 Ohms).
  • \$\begingroup\$ So @KevinWhite , in case that I want to do a simulation in Matlab/ Simulink if I use IGBT, I need to know the parameter, Ron. According to Simulink, Ron is the internal resistance Ron of the IGBT device, in ohms (Ω). The default value is 1e-3 Is it right to go in figure 5, select the Voltage drop according to the current of my application, and then find the Ron= V / I ? \$\endgroup\$ – Yiannis S. Jun 21 '17 at 8:24
  • \$\begingroup\$ Are you using an IGBT model in simulink? Using the resistance value calculated as you describe will not be very accurate but may be adequate. It depends upon what you are looking for in the simulation. \$\endgroup\$ – Kevin White Jun 21 '17 at 14:22
  • \$\begingroup\$ yes I use the IGBT/diode from the library. In case that you can suggest another way to find out the R of my IGBT let me know. Thank you for your time. \$\endgroup\$ – Yiannis S. Jun 21 '17 at 16:07
    \$\begingroup\$ I looked at the IGBT model description and they have both a turn-on voltage (it would be about 0.5V for the device you selected) plus the Ron that would be the slope of the curve after it is turned on - this is not the same as what you calculated. If we draw a straight line from 0.5v to 2.5v the current increases by ~140Amps. This is equivalent to about 7 mOhm. \$\endgroup\$ – Kevin White Jun 21 '17 at 16:39
  • \$\begingroup\$ 0.5 V + 7 mohm seems resonable for a beefy IGBT. \$\endgroup\$ – winny Jun 21 '17 at 16:56
