I'm designing a PCB that is powered by this solar charger using a 3.7V LiPo battery (maybe I'll have to move up to a 4.2 battery). I want to regulate that voltage to 3.3V for feeding a microcontroller and I've selected a TPS73633DBVT, this is a LDO voltage regulator with fixed 3.3V output and 75 to 200mV dropout voltage.
The datasheet says that I can connect the enable to vin if I don't need it but it also says that stuff could happen if I remove the battery from Vin, which is what I can't understand. It says:
When shutdown capability is not required, EN can be connected to VIN. However, the pass gate may not be discharged using this configuration, and the pass transistor may be left on (enhanced) for a significant time after VIN has been removed. This scenario can result in reverse current flow (if the IN pin is low impedance) and faster ramp times upon power-up. In addition, for VIN ramp times slower than a few milliseconds, the output may overshoot upon power-up.
Could someone please explain me what this means and how can I avoid damage when the battery is removed?
It basically tells you that when EN is connected to VIN, it may happen that current flows from the output towards the input, after VIN has been removed. Or/and that upon power-up the ramp up time of the output may be faster than usual.
This is due to the fact that the gate of the MOSFET that is the switching element (in broad terms it is inserted in-series between the input and the output) may maintain some charge, with the result that the MOSFET is still conducting. That's why this reverse current may be observed and the ramp up time may be faster.
The correct way to do it in order to avoid such a case, if you had the EN connected separately from VIN, would be to first drive the EN low to discharge the gate capacitance of the MOSFET and then remove VIN.
There is actually no real risk for the LDO itself or your battery, since it is anyway removed. It's just something they mention because it could be undesirable for some applications. I believe you shouldn't worry about this.
  • \$\begingroup\$ Oh thanks, that makes things more clear. It's good to know that it's not that bad but I'll have to test it anyway. So just in case, I could just connect a pull-up resistor + grounded switch to the EN pin in order to shutdown the regulator before removing the battery, right? \$\endgroup\$
    – Bizcochito
    Jun 22, 2017 at 5:52
  • \$\begingroup\$ Yes, I suppose you could indeed do that. \$\endgroup\$
    – nickagian
    Jun 22, 2017 at 6:42
