I have a product that will be subjected to reliability testing (random vibration and thermal shock) and I need to design a footprint for an SMT power inductor that will give the best mechanical strength to resist damage during vibration testing. I've looked through the IPC 7351 standard but I cant find anything that talks about how different pad size (resulting in different fillet shape) will affect the mechanical strength of the solder joint. The part I am working with is Murata LQH3NPN1R0MMEL. It has a mass of approximately 0.05 grams.
Does anyone have a method for calculating a land pattern for optimal mechanical strength?
  • 4
    \$\begingroup\$ Just use glue on the sides and fix it to the PCB after soldering. \$\endgroup\$
    Commented Jun 23, 2017 at 18:00
  • \$\begingroup\$ @Andyaka wait, really? \$\endgroup\$
    – tuskiomi
    Commented Jun 23, 2017 at 19:01
  • \$\begingroup\$ @tuskiomi maybe you have a suggestion? \$\endgroup\$
    Commented Jun 23, 2017 at 19:07
  • \$\begingroup\$ @Andyaka I've got no clue. \$\endgroup\$
    – tuskiomi
    Commented Jun 23, 2017 at 19:08
    \$\begingroup\$ Not a bad idea Andy. But I don't have the budget for the extra cost of glue. \$\endgroup\$
    – Joel
    Commented Jun 26, 2017 at 16:13
If you're serious about this, you must take into account the mounting geometry of the pcb, the material stiffness, and the location of the inductor. You'll need to do a FEA vibration analysis to identify nodes on the board and coupling of vibrational energy into the inductor footprint.
If you don't have the in-house expertise for that, and don't have access to an outside expert you can hire, you're best off making a blank pcb with just the inductor and shaking/shocking the hell out of it until it fails.
EDIT Sometimes the physical straightforward approach can save a lot of time over careful analysis. There's a story about Edison. Supposedly he assigned a task to a new engineer - determine the capacity of a an oddly-shaped glass bulb. The engineer spent a day taking careful measurements of the bulb and calculating precisely how much volume this entailed, after making due allowances for the (measured, of course, at several places) thickness of the bulb. Edison, it is said, took the bulb, walked over to a water tap, and filled the bulb, then poured the water into a graduated cylinder.
  • \$\begingroup\$ Percussive tuning? \$\endgroup\$
    – tuskiomi
    Commented Jun 23, 2017 at 19:03
    \$\begingroup\$ @tuskiomi - My favorite kind. \$\endgroup\$ Commented Jun 23, 2017 at 19:14
  • \$\begingroup\$ Thanks Beast. Unfortunately I don't have enough information to do a proper analysis. My board is a subsystem that will be mounted on a huge number of host PCBs with various thicknesses, sizes, and mounting arrangements. I guess I'll use a guess and check method, build up a few panels with different size footprints (maybe I'll adjust the paste coverage too) and see what one performs best in the vibration test. I have a feeling a larger pad with maximum paste coverage will be the best. I guess we will just have to wait and see. I'll share my results when they come back from testing. \$\endgroup\$
    – Joel
    Commented Jun 26, 2017 at 16:11
  • \$\begingroup\$ @user36072 - "My board is a subsystem that will be mounted on a huge number of host PCBs with various thicknesses, sizes, and mounting arrangements." In that case, why are you doing vibration tests, and what standards are you using? Without knowing the environment the board will be operating in, any test will be useless. \$\endgroup\$ Commented Jun 26, 2017 at 16:38
  • \$\begingroup\$ I was doing the testing because it was part of my design requirements for an RF module. The testing was Highly Accelerated Life Test (HALT). I ended up just using the IPC standard medium density footprint and didn't have any failures during test. Guess I was just over thinking it. Thanks for the help :) \$\endgroup\$
    – Joel
    Commented May 20, 2021 at 16:26
