I have a device that outputs 12.4 +/- 0.1 mV when it is inactive and 12.9 +/- 0.1 mV while it is collecting data. I would like to trigger another device that expects 3.3V high and 0V low for it's start and stop conditions respectively. Because of the variability of the first device it seems that amplification (of around 660x) would not work. How can I set up a circuit to detect the very small change in the first device's output and activate a 3.3V source for the second device? A comparator seems like the way to go but I'm not sure how to minimize the size of the circuit.
edit: My two devices are a Force Platform system and an Inertial Measurement Unit motion tracking system. I am trying to use the signal from one to trigger the other so that they start data collection synchronously. The IMU is capable of sending and receiving triggers, but the FP are not, so my idea was to split the digital signal of the FP and use the voltage change on one of the output's pins as the trigger. Both are black boxes for me, the companies that produce them will not give me further information as they would prefer to sell me an interface device that does this for me, however, I'm on a graduate student budget...
Thank you! -B
