What are the systematic/standard methods for incorporating the SHDN (shutdown) pin of a buck/boost IC?
Take MAX756 for example (datasheet).
Here are its I_q profile:
MAX756 I_q profile Suppose I'm using an Arduino nano (ATmega328) as the MCU and nRF24l01+ as the transmitter. I'm reading some sensor values via ADC and transferring the data over the RF link. So the system has a sampling frequency (suppose 100Hz). If I want to save battery, the system should sleep most of the time and wake up and transfer the data 100 times a second. All Vccs should come from the boost converter. Now:
1- I should make MCU and nRF sleep but how about the step-up IC? Should it also be shutdown and waked up 100 times a second? I guess I should take the IC's start-up delay into account? Here is its profile: MAX756 start-up delay
Regarding this profile, I guess the IC wakes up in ~2ms... So the maximum sampling rate would be at best 500Hz?
2- What voltage would be on the OUT pin of MAX756 if it is shutdown? The same as Vin? or is it floating?
3- Is SHDN the same as Enable in different ICs?
4- If there is no way that the main MCU could control the SHDN pin, can I use like a 555 timer solution to control SHDN instead of an auxiliary tiny PIC MCU just for controlling the step-up IC? Because using a separate MCU just to control when an IC should shutdown seems to me rather an overdesign solution...Although if it is used in industry I have no problems then
Thank you very much
  • \$\begingroup\$ Read the data sheet. I'm sure everything is there but your first question is for you to decide. \$\endgroup\$ – Andy aka Jun 24 '17 at 10:49
  • \$\begingroup\$ @Andy Aka datasheet says there is a SHDN pin to use...but I'm not experienced enough to know how it is used in industry \$\endgroup\$ – Zeta.Investigator Jun 24 '17 at 10:53
No. Startup times will make that impractical.
0v (turned off)
Yes, but the opposite label.
If you power your MCU from the regulator and the MCU controls the regulator, then when the MCU turns the regulator off it will be committing suicide. No way to turn itself back on, since there is no power to run the MCU.
It is more normal to power different sections of your circuit from different regulators and turn them on/off as you need them.
You need to take the startup time of the regulator into account (most have a "power good" pin to see when they have started up properly). If that takes longer than the sleeping time then switching off while sleeping is not possible.
| improve this answer | |
  • \$\begingroup\$ I've added the start-up delay profile. Is ~2ms too much for a sampling rate of 100 Hz? \$\endgroup\$ – Zeta.Investigator Jun 24 '17 at 10:58
  • \$\begingroup\$ i know this thread is 3 years old, but i'd just like to add that some step up regulators (like the MAX8569) allow Vout be connected straight to the battery (Vbat) when in shutdown mode. So as long as your battery supply has a higher voltage than the minimum needed to keep your MCU running in sleep mode, you should be able to control it with software. I've done it with two AA's, a MAX8569, and a PIC18F2620. \$\endgroup\$ – ezra_vdj Jun 15 at 5:22
For this specific converterr, the output will be 0V. But there are other components (just as an example I mention the TPS61291) with a bypass mode, where the output is connected directly to the input when the converter is shut-down. This could be useful if the MCU could still operate with Vin.
As a general comment, to answer questions like this (I'm mostly referring to your point #1) you have to make your calculations and see how much energy will you save if you do this or that. For example, you want to have 100 Hz sampling rate, that means max sleeping time 10 ms, which of course you will not have. Let's say it will be 5 ms. So if you shutdown the converter you will save around (200 uA - 20 uA) * 5 ms * (100*60*60) (times/h)= 0.09 mAh pro hour. Just very rough calculations here! If you think it is worth it, then do it, otherwise don't. Every design and every system has different specifications and needs, there is no general rule you can apply everywhere!
Also, something else. Have you considered the startup time from sleep mode of the MCU and how much time it will take you to sample, process and transmit your data? It may not be possible to go into sleep mode at all with this sampling rate you are talking about!
  • \$\begingroup\$ @nickagain Thanks for introducing bypass mode step-ups. About the possibility of such task, it seems ATmega328P takes ~2ms at 8MHz to wake up from sleep. nRF24l01+ also seems to wake up from Power Down -> Stand By in 1.5ms (Internal Oscillator) and from Stand By -> TX/RX in ~150us... so worst case is ~2ms... Now I have to check how long reading 3 ADC takes... So it seems possible? \$\endgroup\$ – Zeta.Investigator Jun 24 '17 at 13:50
  • \$\begingroup\$ wait..suppose sampling and processing and sending the data take 8 ms...So the task itself takes ~8ms... And I'm gonna sleep for what, like ~2 ms? Then wake up and be ready in ~4ms? lol! So in total it would be 14ms > 10ms so not 100Hz...It does not save much battery I think even if it's possible... This was your objection? \$\endgroup\$ – Zeta.Investigator Jun 24 '17 at 13:58
    \$\begingroup\$ Yes, exactly, you see? That was generally my point. With 100 Hz sampling rate it is a bit challenging to introduce sleeping. You should calculate your timings in detail if you necessarily want to put your system in sleep. \$\endgroup\$ – nickagian Jun 24 '17 at 14:50
