Recently i've been given a task from my lecturer to implement \$f=\sum(1, 3, 4, 5, 7)\$ on "2-bit multiplexers". That's it. I assume he meant 2:1 MUX.
I've came up with following k-map...
| AB/C | 0 | 1 |
| 00 | 0 | 1 |
| 01 | 0 | 1 |
| 11 | 0 | 1 |
| 10 | 1 | 1 |
\$A\overline B + C\$
... and following 2 schematics:
1)
2) enter image description here
Since the execrise's desscription consists plural multiplexers- is the second example OK? And if the description would mention using only one MUX- is the first example OK?
Both are ok. You have saved 4 pcs of 2 to 1 muxes when compared to canonical 8 input solution.
