Background
I'm going to put together a resistive load, to load a 100W source with an \$8\Omega\$ or \$16\Omega\$ resistor. I'm finding that when to use peak, peak-to-peak or RMS values of voltage, current or power is a subject still shrouded in mystery for those new to the subject or not working in the industry.
Understanding which power to use (RMS, Peak or Peak-to-peak)
When selecting a power rating for the resistor
- do you assume that the power rating on the component website is for a DC supply
- should you calculate the power rating of a component from the RMS power, Peak Power or Peak-to-peak power?
Example: Without taking into account the extra headroom needed (let's run this resistor at maximum permissible power), $$100W_{RMS}=200W_{Peak}=400W_{Peak-to-Peak}$$ therefore should you select a 400W resistor?
Headroom
What is the convention when it comes to selecting headroom on the component's power rating. Is, 1.2 - 1.5 a reasonable factor to multiply by. Let's for the sake of safety put a fuse in line with the resistor to protect it.
My intuition
My intuition tells me to place a fuse in series and either:
- work with the Peak power value in mind because the AC signals will only ever reach a maximum of the peak value, not the peak-to-peak value, and to select headroom in the region of a factor of 1.25 - 1.50. From the example, this would mean selecting a resistor with power rating of \$200W_{Peak} \cdot 1.2 = 250W\$ or \$200W_{Peak} \cdot 1.50 = 300W\$.
or
- work with the peak-to-peak power value which according to the logic in the previous bullet point will surpass the peak power value by a factor of 2 and not chose to use additional headroom. From the example, this would mean selecting a resistor with power rating of \$400W_{Peak-to-peak} = 400W\$
Of these two estimations, the second seems to be sensible due to the apparent large headroom, and therefore component lifespan, but perhaps at an extra financial cost.
Simplification of finding a component
To make it easier to find components within a restricted budged (in the tens of pounds rather than hundreds of pounds) I intend to connect a number of resistors in parallel to distribute the current and therefore power/ component heating. i.e. \$5 \times 40\Omega\$ resistors in parallel \$=8\Omega\$ and \$5 \times 80\Omega\$ resistors in parallel \$=16\Omega\$.
What say you? Thanks in advance
Daniel
