For a highly-sensitive electrometer one needs not only high resistance but also a really small capacitance to achieve certain AC behavior e.g. stability of the opamp.
The figure below shows a typical example of a electrometer circuit with an opamp and can be extracted from this Analog Devices application note.
Layout of a electrometer.
This is equal to the following circuit.
The values given in the schematics plus the noise budget calculations I did, result in a output range (worst-case, \$T_A = 25°C\$) from \$320\, µ V\$ (noise floor) up to \$ 3.3 \, V\$ when a dual power supply (\$V_+=3.3 \, V\$ and \$V_-=-3.3 \, V\$) is used. According to simulation a \$3 dB\$ bandwidth of \$ 530.52 \, Hz\$ works well for a pulsing of the input signal with \$ 200 \, Hz\$. The idea is suppressing noise below this frequency as you mix your signal up from \$0 \, Hz\$ to a higher \$f_{IF}\$. The bandwidth of the system is mainly determined (or from a ideal POV only determined) by the feedback capacitor and can be calculated with
$$f_{3dB} = \frac{1}{R_f C_f 2 \pi}$$
So the capacitance needed is in the femtofarad range (\$30 \,fF\$). Now my question is if you have a feedback path (cf. picture), where you want to avoid coupling impedances (to somewhere outside of this low-current path) of any kind (you use all kind of fancy guarding techniques e.g. via fencing) would you say it is legitimate to use an embedded, self-made pcb cap? You know like basically two plates on TOP and BOTTOM.
I mean the calculations say, that for \$30 \, fF\$ you need two plates with an area of approx \$1.153 \, mm^2\$ when you use FR4 (\$\epsilon_r = 4.7\$) and a PCB with \$1.6 \, mm\$ thickness.
So you have
$$ C = \frac{\epsilon A}{d} $$
which can be rewritten as
$$ A = \frac{C d}{\epsilon} $$
If I got it correctly you can just draw two squares on the PCB on both sides, each of them has the following dimensions $$\sqrt{A} \cdot \sqrt{A}.$$
Conclusion: Can I use an embedded capacitance when working in the femtoampere (YES \$10^{-15}\$ A) range or am I missing out on something here? It is quite hard to get such small capacitances, which is the reason why a embedded capacitor shall be used.
    \$\begingroup\$ I'm confused. You seem to mean "capacitance", not "capacity". But, you describe this "capacity" in Amps (current), not Farads (capacitance). Please edit your question to make it more clear! Thanks. \$\endgroup\$
    – bitsmack
    Jun 28, 2017 at 17:14
  • \$\begingroup\$ Sorry. I corrected my mistakes. \$\endgroup\$
    – m3x1m0m
    Jun 29, 2017 at 8:25
If you define your sensor as a Charge Meter with a sensor of 100 fF =\${10^{-13}}~~\$ [F] and a constant current of \$10^{-15} [A]~~\$ then
\$\frac{dV}{dt} = \frac{Ic}{C} = \frac{10^{-15}[A]}{10^{-13}[F]}={}{10^{-2}}{}[\frac{V}{s}] = t_R~~=\frac{0.35}{f_{-3dB}}\$ from 10% to 90% [V]
thus \$ f_{-3dB} = \frac{0.35}{10^{-2}}~=35 ~ \$ [Hz]
This \$ f_{-3dB}~~\$may be too high for your expectations.
Potential Solutions:
  • reduce stray C by using active guarding around tracks with same CM voltage buffered adjacent to signal tracks such that ΔV=0 thus ΔIc=0 between guard tracks and even less to stray conductors.
  • use chopper stabilized methods in datasheet.
  • use lower input bias current Op Amps.
  • reduce stray leakage R by using air tracks to reduce surface dust creepage R as explained in datasheet
  • Compute track PCB capacitance which is 4x air to reduce conductor capacitance to sensors using wider separation and air tracks perhaps with AWG 30~40 magnet wire.
  • use gold leaf sensors and measure displacement like Coulomb did which had a long decay time [s]
  • use circuits employed for ESD meters to measure discharge or charge with S&H with suitable protection. They often use a charge amplifier (TIA) commonly used for large piezo accelerometers to measure vibration charges to convert to voltage but maybe also BW limited.
Comments?
  • \$\begingroup\$ Thank you for your answer. I had another approach calculating the \$ f_{3dB}\$. $$f_{3dB} = \frac{1}{R_f C_f 2 \pi}$$ You can get this equation by using \$ P = U \cdot I^*\$. So this would result in approx. 160 Hz. It is nothing more than a parallel resonant circuit consisting of R and C. I can not just put C to 0 as I have a pole. So you can see in the LTSpice ac analysis, that it is escalating at some point. That is why I need a capacitance. A really small one. And my question is: Can I do this by putting an embedded capacitance in the feedback loop or will this have negative side eff.? \$\endgroup\$
    – m3x1m0m
    Jun 29, 2017 at 8:40
  • \$\begingroup\$ To improve s21 gain + phase response we need you to give a spec and schema model on your requirements. Then it will be obvious what to do with phase margin using the correct source capacitance and lead-lag compensation circuit. \$\endgroup\$ Jun 29, 2017 at 13:54
  • \$\begingroup\$ I edited the original post. \$\endgroup\$
    – m3x1m0m
    Jun 29, 2017 at 22:08
  • \$\begingroup\$ @m3x1m0m by specs I mean what are your requirements for Signal Input, Output, SNR, Signal BW, Noise BW, dynamic range, and accuracy requirements for calibration, limitations on sensor size, etc. \$\endgroup\$ Jun 30, 2017 at 5:34
  • \$\begingroup\$ I hope I collected all the information needed to design such a system properly now. It is not a communication system so I do not really have a SNR. But I guess, that is OK? Basically everything above the noise floor (\$320 \, µ V\$ worst-case at the output) is visible. \$\endgroup\$
    – m3x1m0m
    Jun 30, 2017 at 8:41
