I'm designing a circuit, and a section of it is as follows:
What circuit can i use to allow OA1 to follow the Non-inverting input from 0 to 5V exactly, and anything above 5V in the input remains 5V on the output?
(i thought of using 2 resistors or a trimmer to reduce voltage on the input, but i have no use of the 5-10V range, and i want to use the full 0-5V range on the output)
(the 0-10V input is not available for redesign, the OA2 doesn't exists, but i placed it there to signify a high impedance circuit after the output.)
Note: I'm trying to be accurate, i could use a resistor+zener diode on the Output to limit to the closer commercial value for zeners eg. 5.6V, but there must be a better and more precise way to do this..
