I am using SAMD21 with FreeRTOS. I am putting the system on sleep level Standby and relying on a TC that works as a systick for the tickless FreeRtos to wake up the MCU however, when the debugger isn't connected (which it shouldn't be) the MCU goes to sleep and never wakes up.
I have tried it with the internal 8M and external 32K and had no lock. The only clock which the CPU can wake up from sleep with is ULP32K which is always on so On Demand doesn't really mean much in that case.
This is the snippets of the TC and my Clock configurations:
// From conf_clock.h
/* SYSTEM_CLOCK_SOURCE_OSC8M configuration - Internal 8MHz oscillator */
# define CONF_CLOCK_OSC8M_PRESCALER SYSTEM_OSC8M_DIV_1
# define CONF_CLOCK_OSC8M_ON_DEMAND true // <--
# define CONF_CLOCK_OSC8M_RUN_IN_STANDBY false // <--
/* Configure GCLK generator 5 */
# define CONF_CLOCK_GCLK_5_ENABLE true
# define CONF_CLOCK_GCLK_5_RUN_IN_STANDBY true // <--
# define CONF_CLOCK_GCLK_5_CLOCK_SOURCE SYSTEM_CLOCK_SOURCE_OSC8M
# define CONF_CLOCK_GCLK_5_PRESCALER 1
# define CONF_CLOCK_GCLK_5_OUTPUT_ENABLE false
// From tickless.c
void vPortSetupTimerInterrupt(void)
// Struct for configuring TC
struct tc_config tcconf;
// Set up configuration values
tc_get_config_defaults(&tcconf);
tcconf.clock_source = GCLK_GENERATOR_5;
tcconf.counter_size = TC_COUNTER_SIZE_32BIT;
tcconf.run_in_standby = true; // <--
tcconf.clock_prescaler = TC_CLOCK_PRESCALER_DIV1;
tcconf.wave_generation = TC_WAVE_GENERATION_MATCH_FREQ;
// Initialize the TC
tc_init(&tc, TICK_TC, &tcconf);
// Register and enable callback for freeRTOS tick handler
tc_register_callback(&tc, (tc_callback_t) xPortSysTickHandler, TC_CALLBACK_CC_CHANNEL0);
tc_enable_callback(&tc, TC_CALLBACK_CC_CHANNEL0);
// Set top value equal to one OS tick
tc_set_count_value(&tc, 0);
tc_set_top_value(&tc, TIMER_RELOAD_VALUE_ONE_TICK);
// Enable the timer
tc_enable(&tc);
What I am missing here.
Is this the same issue people are talking here -> http://www.avrfreaks.net/forum/samd21-samd21e16b-sporadically-locks-and-does-not-wake-standby-sleep-mode
Just to clarify, the sleep level IDLE_2 works and CPU can recover from sleep successfully.
