I am looking to charge my iphone using a thermoelectric power generation device. The thermoelectric generator device has positive and negative leads, and I have tried connecting the wires from the USB cable (which I cut open and spliced) directly but no luck. I AM NOT LOOKING TO USE THE USB AND PLUG IT INTO A WALL/COMPUTER.
The thermoelectric generator device produces about .5 Watts and 1 amp.
Is it likely that the phone is not charging because the power supply is too low? Or is likely that the wire connection is poor? Does the power supply have to supply 2.1 Amps and 5 Volts for the phone to charge?
Thanks.
closed as off-topic by Dmitry Grigoryev, Enric Blanco, Wesley Lee, PeterJ, uint128_t Jul 4 '17 at 21:59
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Dmitry Grigoryev, Enric Blanco, Wesley Lee, PeterJ, uint128_t
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ 0.5 Watts and 1 amp means your voltage is about 0.5V, which is 10 times lower than you phone needs. \$\endgroup\$ – Dmitry Grigoryev Jun 30 '17 at 7:17
That's not going to work.
An iPhone needs a minimum of 5V / 500 mA to charge. This comes out to 2.5W, which is five times higher than the output of your TEG.
It's can't be charge due to there's no data wire has been connected,only + and - connections can't be charge the ipnone, You should connect data port also.either you can Short both TX and RX (Middle 2 wire)of charging cable from USB side's.
