When copying and pasting a component that already has a designator in an Altium schematic document and assigning it a new designator, the designator from the original part still shows up as a ghost, as shown in the picture.
example
How do I get rid of this?
  • 4
    \$\begingroup\$ Who ya gonna call..... \$\endgroup\$ – Andy aka Jun 30 '17 at 14:25
    \$\begingroup\$ usually this will go away after you recompile the design a few times. But if you are using repeat-blocks and multichannel techniques, the master sheet will display the designators of the child sheets \$\endgroup\$ – Luke Gary Jun 30 '17 at 14:47
  • \$\begingroup\$ I think you misunderstand the compilation and board level annotation processes. Altium has some good documentation online you should read first. It will help you more than any piecemeal answers will. \$\endgroup\$ – Joel Wigton Jul 2 '17 at 15:46
You do not have to do anything to it. They do not show up in any exports and do not affect the design in any noticeable way. All it is doing is showing the expanded compiled name of the designator. To get rid of it you should be able to go to your DXP preferences --> Schematic --> Compiler and under "Compiled Names Expansion" change the dropdown next to "Designators" from "Display superscript" to "Don't display" (or whatever the actual text is -- I can't remember off the top of my head).
Others have pointed out how to get rid of this. However, I advise you not to get rid of this!
Designators will be displayed grayed-out when the schematic was changed but not yet copied over to your PCB layout. You can therefore match the components to your current design even though the designator numbering was changed.
It will go away once you import the schematic changes into the design. Altium is trying to help you here, for which you paid handsomely. Let it help you!
