I have been trying to debug my code and realized that my watchpoints for variable never execute. When I looked into this problem online, I encountered similar situations and the response they received was their microcontroller may not be supported. I have an STM32F4 and I am using GDB on Ubuntu with st-util. Breakpoints currently work but watchpoints don't. How can I add support for it?
    \$\begingroup\$ Watch points should be supported with stlink and STM32F4. Have you tried using another GDB server, like OpenOCD? \$\endgroup\$ – Tony K Jul 3 '17 at 4:09
  • \$\begingroup\$ Also note that the C/C++ code in question may have been optimized out or inlined, so the debugger was not able to find it. Try compiling with -Og -g3 which optimizes for debug and includes extra debug info. \$\endgroup\$ – Tony K Jul 3 '17 at 4:12
  • \$\begingroup\$ @TonyK I haven't tried using OpenOCD. I will make sure to try that. I added both those options for compiling but with no prevail. I also tried using st-util v2. \$\endgroup\$ – h3y4w Jul 3 '17 at 11:33
  • \$\begingroup\$ @TonyK Using OpenOCD seems to have worked. If you make an answer I will be glad to accept it. Thanks again! \$\endgroup\$ – h3y4w Jul 3 '17 at 11:59
It seems that st-until has issue with setting watchpoints on STM32F4, even though it is supposed to be supported. As I previously noted, OpenOCD is an alternative and it looks like switching to it has resolved the issue for you.
