I'm working on a project that allows a user to crank a hand generator while current and voltage sensors measure the output. After the user finishes cranking, software displays information about how much power was output.
This is the generator we're using: http://windstreampower.com/Human_Power_Generator.php
It seems like it should be a simple problem. However, in the current setup, I've been using the provided 12V voltage regulator and feeding power into 12V incandescent bulbs, and once the rig gets under heavy use, the voltage regulator burns out, and the bulbs blow.
The setup is like this:
Hand Crank => 12V Voltage Regulator => 12V Incandescent Light Bulb (50W)
So, I'm wondering if there is an alternative approach to this configuration (we don't need light bulbs or anything visible). Maybe feeding the crank directly into a 12V battery with some type of charge regulator and a constant drain? Maybe connecting the generator to several bulbs in series?
What is the simplest, most inexpensive dummy load we can attach to the generator, just so we can get current and voltage readings of the user's output while they crank?
