The toggle circuit below works well, but I noticed that there will be current spike when the switch is closed, i.e., when switch is closed, the two caps will charge each other without resistor in between, the energy is small, but current will spike.
Is it necessary to add a 1k resistor between the 0.01uF cap and the ground?
Or is the 0.01uF cap redundant and can be removed? (I assumed it is added to ensure the toggle is on OFF state when power on, but seems not really needed).
