I have this project listen below and im not sure where to start maybe someone can give me a few pointers or perhaps point me in the right direction of starting this? Thanks!!
Input: A, B = octal digits (see representation below); Cin = binary digit
Output: S = octal digit (see representation below); Cout = binary digit
Task: Using binary FAs, design a circuit that acts as an octal FA. More specifically, this circuit would input the two octal digits A, B, convert them into binary numbers, add them using only binary FAs, convert the binary result back to octal, and output the sum as an octal digit, and the binary carry out.
Input/Output binary representation of octal digits
Every octal digit will be represented using the following 8-bit binary representation:
Octal 8-bit Input Lines:
Digit: 0 1 2 3 4 5 6 7
0 1 0 0 0 0 0 0 0
1 0 1 0 0 0 0 0 0
2 0 0 1 0 0 0 0 0
3 0 0 0 1 0 0 0 0
4 0 0 0 0 1 0 0 0
5 0 0 0 0 0 1 0 0
6 0 0 0 0 0 0 1 0
7 0 0 0 0 0 0 0 1
You are required to design the circuit in a structured way.
