I'm new to the SAM product line from ATMEL. I purchased the original ATMEL Xplained board, which works nicely with the ATMEL studio for programming & debugging. I know that the Xplained board carries it's own chip for programming (I guess this is like a small ICP device).
I now want to bring the SAM D21 to my own PCB. As a starting point, I came across the dev breakout board from Sparkfun (see https://www.sparkfun.com/products/13672).
I don't see an additional chip on the sparkfun board, and I'm wondering if I can use the ATMEL Studio for programming/debugging with the ATMEL-ICE device?
Many Thanks Christian
  • \$\begingroup\$ The only problem is does ATMEL Studio or ATMEL-ICE device support it \$\endgroup\$ – Long Pham Apr 24 '18 at 8:12
  • \$\begingroup\$ oh it works quite well! Also with debugging. I ended up using the SWD interface \$\endgroup\$ – Chris Apr 24 '18 at 16:32
    \$\begingroup\$ Good for you !! \$\endgroup\$ – Long Pham Apr 24 '18 at 18:00
You need to go through the Atmel SAMD21 datasheet. I am currently using SWD pins for debugging an Atmel SAMD20 using Raspberry Pi3 which is running OpenOCD. You can use the same SWD pins to connect to an Atmel-ICE or Segger J-Link to program/debug.
You can use this as a reference: atsamd21-arduino SWD debugging
